How to determine video clocking frequency and how to do VGA bits conversion
I'm studying video output with VGA and I'm having two questions about how it works:
1. How do I determine the video clocking frequency given a resolution and a frame rate?
2. I want to display a RGB image, each channel having 8 bits. How do I convert these 8 bits to ZedBoard VGA specification of 4 bits per channel?
Thanks in advance
Tags (2)
Scholar watari
Re: How to determine video clocking frequency and how to do VGA bits conversion
Hi @tiago0297
I strongly suggest following VESA CVT video timing and/or CEA video timing.
These definitions are suitable for you.
I'm not familier with ZedBoard. However, generally, I recommend to refer this connections.
RGB_IMAGE_R[1] = ZEDBORD_R[0]
RGB_IMAGE_R[3] = ZEDBORD_R[1]
RGB_IMAGE_R[5] = ZEDBORD_R[2]
RGB_IMAGE_R[7] = ZEDBORD_R[3]
Best regards,
Scholar watari
Hi @tiago0297
Best regards,
Thanks for the help!
