How to encode 1920x1080i using H265
In pg252-vcu-v12.pdf, it says the VCU can decode and encode of interlaced video like 1920x1080i.
I use ZCU106 with rdf0428-zcu106-vcu-trd-2018.3 vcu_sdirx prebuilt. The format of sdi-input is "1920x1080x50i"
The output of command "xmedia-ctl -p -d /dev/media0":
Media controller API version 4.14.0
Media device information
driver xilinx-video
model Xilinx Video Composite Device
serial
bus info
hw revision 0x0
driver version 4.14.0
Device topology
- entity 1: vcap_sdi output 0 (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "a0080000.v_proc_ss":1 [ENABLED]
- entity 5: a0030000.v_smpte_uhdsdi_rx_ss (1 pad, 1 link)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Source
[fmt:UYVY8_1X16/1920x540@1000/25000 field:alternate]
-> "a0080000.v_proc_ss":0 [ENABLED]
- entity 7: a0080000.v_proc_ss (2 pads, 2 links)
device node name /dev/v4l-subdev1
pad0: Sink
[fmt:UYVY8_1X16/1920x1080 field:alternate]
<- "a0030000.v_smpte_uhdsdi_rx_ss":0 [ENABLED]
pad1: Source
-> "vcap_sdi output 0":0 [ENABLED]
And I used the gstreamer to test:
 gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! video/x-raw,interlace-mode=alternate,format=NV16,width=1920,height=1080,framerate=25/1 ! omxh265enc ! filesink location="/mnt/de.h265"
But the output is not correct.
Tags (2)
Re: How to encode 1920x1080i using H265
PG252 December 5th, 2018 page 135 has some examples of how to use the VCU with interlaced video.
1. filesrc -> omxh265dec -> omxh265enc -> filesink
gst-launch-1.0 filesrc location=file_1080i.h265 ! omxh265dec ! omxh265enc target-bitrate=10000 control-rate=2 ! queue max-size-bytes=-1 ! filesink location=file.h265
2. v4l2src -> omxh265enc -> omxh265dec -> kmssink
gst-launch-1.0 v4l2src io-mode=4 ! video/x-raw,interlace-mode=alternate,format=NV16_10LE32,width=1920,height=1080,framerate=30/1 ! omxh265enc target-bitrate=10000 control-rate=2 ! omxh265dec ! queue max-size-bytes=-1 ! kmssink bus-id=drm-pl-disp-drv connector-properties="props,sdi_mode=0,sdi_data_stream=2,is_frac=0"
I recommend you try doing a filesrc and filesink before tyring to do a live source and sink.
Chris
Video Design Hub | Embedded SW Support
The error of gstreamer is :
Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Setting pipeline to PLAYING ... New clock: GstSystemClock Redistribute latency... ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not read from resource. Additional debug info: ../../../git/sys/v4l2/gstv4l2bufferpool.c(1091): gst_v4l2_buffer_pool_poll (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: poll error 1: Invalid argument (22) Execution ended after 0:00:00.063317956 Setting pipeline to PAUSED ... Setting pipeline to READY ... Setting pipeline to NULL ... Freeing pipeline ...
Scholar watari
Hi @gefei-liuqi
I'm not sure. But would you change height parameter from 1080 to 540 ?
Best regards,
Hi, @watari
Thanks for your response. when I changed height parameter from 1080 to 540, it also occurs error.
xmedia-ctl -d /dev/media0 -p
driver xilinx-video
serial
bus info
hw revision 0x0
Device topology
pad0: Sink
pad0: Source
pad0: Sink
[fmt:UYVY8_1X16/1920x540 field:alternate]
pad1: Source
[fmt:VYYUYY8_1X24/1920x540 field:alternate]
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=4 ! video/x-raw,interlace-mode=alternate,format=NV12,width=1920,height=540 ! queue ! filesink location="/mnt/en.h265"
The error is:
Execution ended after 0:00:00.493733813
Hello, anyone can give some advice?
Thanks!
Chris
Hi @gefei-liuqi ,
Do you have any update on this topic?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Thanks for your reply @florentw
I donot get some progress unitl now. It cannot work for encoding 1080i50 using h265.
It is very important for us because the vpss-deinterlace cannot work. So we have to encode 1080i50 using h265.
I used the commands as you list, but still cannot work.
what else should I try?
Hi @gefei-liuqi ,
Can you share the file you have used for the interlaced input?
Florent
Thanks! @florentw
I donot have the file file_1080i.h265 . I tested the H265's encoder  with the 1080i-SDI input in ZCU106.
I tried your command  buf it failed and I want to know:
What format should be set for v_proc_ss and vcap_sdi Entities in V4L2 video pipeline?
I have tried many formats through Xmedia-ctl, but cannnot work.
Thanks Very Much!
