Observer jinhanharu
How to generate NTSC timing by using VTC(Video Timing Controller)
I have to design NTSC 480i by using Zynq and ADV7123(Analog Device Video DAC component)
so I could get the image but there is an error.
sometimes, even,odd lines swaps so I checked the waveform but there aren't Equalizing pulses and serration pulses
when I read the PG016, VTC doesn't support  NTSC.
so I don't know how to generate the signals(equalizaing pulses and serration between even and odd fields)
my vtc is v6.1 and only generation mode(not detection mode)
Thank you in advance.
Re: How to generate NTSC timing by using VTC(Video Timing Controller)
check page number 23
https://www.xilinx.com/support/documentation/ip_documentation/v_axi4s_vid_out/v3_0/pg044_v_axis_vid_out.pdf
Thanks and Regards
Balkrishan
