How to stop and start VDMA READ(mm2s) and WRITE(s2mm) using extern fSync
Hi Folks,
we are writing and reading DDR through VDMA.
we want to stop VDMA(Read and Write)  for external interrupt signal for 500us and again VDMA(Read and Write) start for 160us.
we are currently using externfsync . How to configure external fsync?
Please suggest us regard this.
Thanks and Best Regards
Vinod Sajjan
Re: How to stop and start VDMA READ(mm2s) and WRITE(s2mm) using extern fSync
@vinod.sajjan
It depends on your application. You can use Circular_Park register to set read side at Park mode. When it stops, let the frame stop at last frame.
Park ModeEngine will park on frame buffer referenced by PARK_PTR_REG.RdFrmPntrRef. or you can use soft reset to totally reset the channel, when reset is release, VDMA is back to normal operation.
The advantage of using fsync is to let image restart from the first of pixel. For example, when you stops reading, you have no clue image stops at which pixel, it's very likely the last pixel stops in the middle of the image. After some micro seconds, when you restart reading, the first pixel of new image will be loaded, and read out. If you don't use fsync, you will see some part of two images are mixed in the same screen.
HI @vinod.sajjan,
What do you mean by "How to configure external fsync?"
Do you need to know how to configure the VDMA?
Florent
Hi @florentw,
Thank you for your support.
Yes i want known, how to configure the VDMA for External fsync mode (means not free running mode).
here i want to known how exactly mm2s_Fsync of VDMA works?
Please Suggest me regarding this.
Vinod Sajjan
Hi @vinod.sajjan,
The fsync won't help you to start/stop the VDMA. You need to do this using your processor.
The fsync is just to synchronize the VDMA with the timing signals.
Florent
This thread seems duplicate to the another one in this board. Let me repeat the answer here :
tready can be used to control the read side, whether slave side is ready to read out the data or not
After you stop, and then restart, you can issue an fsync pulse. fsync should be only asserted for one cycle.
When an fsync happens, the VDMA flushes its buffers, advances the genlock pointers, and starts the new frame at the address in MM2S_START_ADDRESS registers.
If you are familiar with VIP, you can simulate VDMA and evaluate the behaviour of fsync by using a really small test frame. If not, probably you need to capture the fsync and read side AXI Streaming interface in ILA
Hi @xud,
In our application we need to stop the VDMA for some micro seconds, because we have limited size of buffer in target side (32KB buffer) and again we need to start VDMA. Please kindly suggest us how to start and stop the VDMA read and write.
Vinod Sajjan
Hi @vinod.sajjan,
The correct way to start / stop the VDMA is to use the configuration registers
Florent
Hi @florentw,
Thank you for your support and concern.
We have doubt, how fsync is useful in VDMA?
Is there any VDMA configuration side of IP for start and stop the VDMA, because we need to stop and start the VDMA side of PL for our application.
Vinod Sajjan
Hi @vinod.sajjan,
Fsync gives the information when to start a new frame. It is not used to stop the VDMA.
I do not think there is any way to stop the VDMA directly from the PL. One solution might be to disable the input clock for the AXI4S interface but I am not sure if this will work properly
Florent
@vinod.sajjan
