How to store video on SD CARD from CSI-2 signals ?
Hello everyone,
I am working on the ULTRA96 development board which has an Ultrascale+ FPGA embedded and I would like to store videos on a SD CARD from CSI-2 camera (Raspberry pi camera). I already know that I need an IP to get CSI-2 signals on my FPGA but after that I don't really know what needs to be done. I suppose I have to encode my data to be able to record it but I don't really know how to do it.
Does anyone know how to do it ?
Scholar watari
Re: How to store video on SD CARD from CSI-2 signals ?
Hi @corentin.meneau
That sounds grate.
But how to encode H264 by hardware ?
It's no problem, if you already consider it as encoding software or using VCU.
BTW, here is my solution.
Would you refer it ?
Plan A)
Encode CSI signal by VCU or other encoder unit -> Deal with encoded video data by V4L2 on linux -> Store video data
Plan B-1)
Covert CSI signal to AXI4Stream -> Store stream data by VDMA into frame buffer -> Read stream data from frame buffer -> Store stream data into SD Card by using sector number -> After that convert sector data to file by "dd" command on linux. => Convert raw data to H264 by ex. ffmpeg or libavcodec on linux.
Plan B-2)
Covert CSI signal to AXI4Stream -> Store stream data into SD Card by using sector number -> After that convert sector data to file by "dd" command on linux. => Convert raw data to H264 by ex. ffmpeg or libavcodec on linux.
Best regards,
Scholar drjohnsmith
you might want to think about the data rate of the camera data and the SD card,
Scholar watari
Hi @corentin.meneau
How do you deal with stored data ? For file by file system or stored data as raw data by sector unit ?
You need to consider it, too.
Best regards,
Thanks for your reply. Someone already told me that but it's hard to find exactly which data rate I have in all parts of my system. I suppose after the video codec the data flow will drecrease drastically.
File by file seems good to me. I would like to store video in h264 format. I think it will be easier to read stored videos on a computer after. What do you think ?
Scholar watari
Hi @corentin.meneau
That sounds grate.
Plan A)
Plan B-1)
Plan B-2)
Best regards,
That's perfect ! This is exactly what I was looking for.
To encode H264 I have found some IPs which are able to do that from AXI4 signals but I will probably use your first solution because I am not sure yet but I am not sure to still use ULTRA96 board but instead the MPSoC module from Trenz Electronic with the Zynq UltraScale+ ZU4EV which already have a VCU embedded.
Thanks a lot for your help.
