Visitor vyudovich
I/O type for DP AUX
Could you advise what I/O type should I use for DisplayPort Auxiliary channel?
Vladimir
Re: I/O type for DP AUX
@vyudovich which device are you targeting?
For example all the way back in Spartan-6 there was a display_port IO standard that let you interface the AuX channels.
In this case this was a 2.5V/3.3V bi-directional differential signalling interface. My understanding was that this was a very slow link.
maybe look at the device you were looking to interface with.
Also look at the IP guides for this
http://www.xilinx.com/support/documentation/ip_documentation/dp_rx_subsystem/v2_1/pg233-displayport-rx-subsystem.pdf
http://www.xilinx.com/support/documentation/ip_documentation/dp_tx_subsystem/v2_1/pg199-displayport-tx-subsystem.pdf
@florentw maybe you can point @vyudovich in the right direction here.
Visitor vyudovich
I am using V7
thank you!
HI @vyudovich
FPGA IO-STD used for the half duplex  differential AUX channel  is  LVDS.
you can always generate an example design of a Display port subsystem for KC705  and   check for any implementation details like this.
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
Hi @vyudovich,
If everything is clear for you on this subject, please kindly mark it as solved by marking a response as solution.
Kind Regards,
Florent
Florent
