Observer ericzerbib
I have issue in Audio HDMI out in profile vcu_audio from 2018.3
Hello all
I'm trying the vcu_audio pre-build binaries from TRD 2018.3
And when I wants to hear audio on my TV (connected to HDMI), I can't hear anything.
I have tested multiple application
 ./bin/vcu_gst_app ./config/1080p60/Display/Single_1080p60_AVC_HIGH.cfg
(see video but no audio)
even simple gstreamer command
gst-launch-1.0 audiotestsrc ! audioconvert ! audioresample !   audio/x-raw, rate=44100, channnels=2, format=S24_32LE ! alsasink device="hw:1,0"
aplay -l is reporting two card as expected and using "hw:1,0" should go to the FPGA card (audio formater which should be connected to hdim tx )
**** List of PLAYBACK Hardware Devices ****
card 0: monitor [DisplayPort monitor], device 0: (null) xilinx-dp-snd-codec-dai-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: monitor [DisplayPort monitor], device 1: (null) xilinx-dp-snd-codec-dai-1 []
Subdevices: 1/1
card 1: Default [xilinx FPGA sound card], device 0: (null) i2s-hifi-0 []
Subdevices: 1/1
Note that audio on DP (using interface hw:0,0 or hw:0,1 is working and audio is heard in monitor attached to the DP
Is something I'm missing ?
Observer ericzerbib
Re: I have issue in Audio HDMI out in profile vcu_audio from 2018.3
I have better information to submit in the case
There is one monitor LG that is able to play the Audio sound fine
but other TV like Samsung/Phillips not.
Analyzing the sound "info frame" are giving these data
Channel count 0
Rate : 44.1
but the format expected is  S24_32LE (24 bits in 32 bits, signed, little endian)
@ericzerbib
Some Samsung tv has multiple HDMI ports, one of them doesn't play audio for 4kp60. Can you try a different HDMI port, and see if it makes any difference?
Also the default modetest port is set to DP.
When you setting the input to 1080p60 format, please use command below to ensure HDMI Tx is set to 1080p60 :
modetest -M xlnx -s 30:1920x1080-60@XB24 &
If you can hear audio with 1080p, I think the problem is to do with Samsung's HDMI port.
Observer ericzerbib
I think that if I have successfully hear audio on LG is because this monitor is less restrictive on the AV info frame than  other TV, the fact is that the analyzer is not retrieving full audio info is a bug in the audio block FPGA,
Samsung an Phillips are not small vendor of TV and our final solution MUST be able to work with this TV also. Note that the experience was tested also under 1080p60 and 4k30 not on 4k60.
Trying another HDMI port is not acceptable as solution...
Hi @ericzerbib
Sorry for the late response, I was on and off last week.
I have tested prebuild image with your command, audio isn't stable at all. It keeps toggling between the two images below.
I will have a closer look at this issue.
In the meantime, can you let me know your system setup please? Which audio source do you use?
Observer ericzerbib
Thanks you for your response
Generally my source is a PC which plays to an encoder and then the stream is sent to the local network then displayed as decoded to the TV
Observer ericzerbib
My Assumption is the the fact that N=6144 and CTS=199529 is wrong, the setup was full HD 1920x1080p60 and audio was 48 kHz (even if you set 44100 the sound is audible just at 48000)
Note in the spec
https://glenwing.github.io/docs/HDMI-1.4b.pdf page 124
we can see that TMDS clock 148.5 Mhz / 48kHz
N=6144 CTS=148500
@ericzerbib
I have generated the vcu_audio design, and notice the cts and n value are generated from HDMI_ACR_CTRL, which is derived from HDMI RX.  We have tested those values in HDMI example design for a few Vivado versions, they are fine.
Can you use "cat hdmi_info"command(under associated path) to get HDMI RX and HDMI TX information, so we can see if audio parameters are expected :
root@zcu106_vcu_trd:/sys/devices/platform/amba_pl@0/a0000000.v_hdmi_rx_ss# cat hdmi_info
root@zcu106_vcu_trd:/sys/devices/platform/amba_pl@0/a0020000.v_hdmi_tx_ss# cat hdmi_info
Observer ericzerbib
root@KDS-DEC10-1:/sys/devices/platform/amba_pl@0/a0000000.v_hdmi_rx_ss# cat hdmi_info
Rx Info
Mode: DVI
Status: No input stream detected
Link quality
Link quality channel 0 : good (4)
Link quality channel 1 : good (4)
Link quality channel 2 : good (4)
root@KDS-DEC10-1:/sys/devices/platform/amba_pl@0/a0020000.v_hdmi_tx_ss# cat hdmi_info
Stream Info
Color Format: RGB
Color Depth: 8
Pixels Per Clock: 2
Mode: Progressive
Frame Rate: 30Hz
Resolution: 3840x2160@30Hz
Pixel Clock: 297000000
Stream Timing
HSYNC Timing: hav=3840, hfp=176, hsw=88(hsp=1), hbp=296, htot=4400
VSYNC Timing: vav=2160, vfp=08, vsw=10(vsp=1), vbp=072, vtot=2250
Tx Info
TX Mode - HDMI
HDMI Video Mask is Disabled
Scrambled: 0
Sample rate: 1
Audio channels: 0
Note the Audio CTS/N from devmem for PL audio address
root@KDS-DEC10-1:~# ./dump_reg.sh 0xa0056000
0xa0056000 - 0xDEADBEEF = 3735928559
0xa0056004 - 0x00000003 = 3
0xa0056008 - 0x000616D2 = 399057
0xa005600c - 0x00001800 = 6144
Note 2: expected by spec N=5120 /CTS=247500
@ericzerbib
Thanks for providing the HDMI info, there is something wrong with Audio settings.
1. Audio channel in TX log, is Audio channels: 0, which should be 2
2. CTS/N values. I checked in block diagram, the cts/n of HDMI TX is indeed derived from HDMI RX side, but you mentioned there is a register used to store those values. I need to discuss with relevant team, and try to double check how cts/n is provided to HDMI TX
In the meantime, can you use a HDMI Source(if your laptop has HDMI connector) to do some test, and see if you can get expected audio?
