Visitor gmueller
I2S Transmitter FIFO size
Hello!
We would like to use the i2s IP for low latency audio processing. Is there a way to reduce the FIFO size below th 64 samples? The documentation states that transmission is only started when the FIFO is half filled.
Tags (2)
Re: I2S Transmitter FIFO size
Hello @gmueller ,
As mentioned in the PG308, The FIFO Depth allowed values are as shown in the below "FIFO Depth" Image. So, the minimum FIFO Depth is 64. So, User can't reduce the depth value below then the 64. I hope this heps to You.
Ashok.
Visitor gmueller
So, is there a bug tracker or ticket system where I could request a change of the IP?
Hi @gmueller
You need to contact your FAE to ask for an enhancement of the IP with the technical reason of it and the detail of your project. Then he will contact marketing with your business case and marketing will decide if the IP should be change or not.
Florent
