Observer ccasanova
I2S transmitter and I2S receiver with petalinux
I am trying to use a Zynq 7010 with Petalinux.and an I2S transmitter or an I2S receiver or both implented at PL
When I boot the Petalinux made with the device tree that has these two modules, any ALSA soundcard appears that it is wrote in the wiki.
Is it necesarry to modify the device tree with some change after the hardware definition in Vivado 2019?
I attach one image of the Vivado project with only an I2s transmitter and the device tree of PL part.I2s transmitter.JPG
* CAUTION: This file is automatically generated by Xilinx.
* Version: XSCT 2019.1
* Today is: Mon Jul 29 15:34:45 2019
amba_pl: amba_pl {
#address-cells = <1>;
#size-cells = <1>;
compatible = "simple-bus";
ranges ;
axi_fifo_mm_s: axi_fifo_mm_s@43c00000 {
/* This is a place holder node for a custom IP, user may need to update the entries */
clock-names = "s_axi_aclk";
clocks = <&clkc 15>;
compatible = "xlnx,axi-fifo-mm-s-4.2";
interrupt-names = "interrupt";
interrupt-parent = <&intc>;
interrupts = <0 29 4>;
reg = <0x43c00000 0x10000>;
xlnx,axi-str-rxd-protocol = "XIL_AXI_STREAM_ETH_DATA";
xlnx,axi-str-rxd-tdata-width = <0x20>;
xlnx,axi-str-txc-protocol = "XIL_AXI_STREAM_ETH_CTRL";
xlnx,axi-str-txc-tdata-width = <0x20>;
xlnx,axi-str-txd-protocol = "XIL_AXI_STREAM_ETH_DATA";
xlnx,axi-str-txd-tdata-width = <0x20>;
xlnx,axis-tdest-width = <0x4>;
xlnx,axis-tid-width = <0x4>;
xlnx,axis-tuser-width = <0x4>;
xlnx,data-interface-type = <0x0>;
xlnx,has-axis-tdest = <0x0>;
xlnx,has-axis-tid = <0x0>;
xlnx,has-axis-tkeep = <0x0>;
xlnx,has-axis-tstrb = <0x0>;
xlnx,has-axis-tuser = <0x0>;
xlnx,rx-fifo-depth = <0x200>;
xlnx,rx-fifo-pe-threshold = <0x5>;
xlnx,rx-fifo-pf-threshold = <0x1fb>;
xlnx,s-axi-id-width = <0x4>;
xlnx,s-axi4-data-width = <0x20>;
xlnx,select-xpm = <0x0>;
xlnx,tx-fifo-depth = <0x200>;
xlnx,tx-fifo-pe-threshold = <0x5>;
xlnx,tx-fifo-pf-threshold = <0x1fb>;
xlnx,use-rx-cut-through = <0x0>;
xlnx,use-rx-data = <0x0>;
xlnx,use-tx-ctrl = <0x1>;
xlnx,use-tx-cut-through = <0x0>;
xlnx,use-tx-data = <0x1>;
i2s_transmitter_0: i2s_transmitter@43c10000 {
aud_mclk = <12288135>;
clock-names = "s_axi_ctrl_aclk aud_mclk s_axis_aud_aclk";
clocks = <&clkc 15>, <&misc_clk_0>, <&clkc 15>;
compatible = "xlnx,i2s-transmitter-1.0", "xlnx,i2s-transmitter-1.0";
interrupt-names = "irq";
interrupts = <0 30 4>;
reg = <0x43c10000 0x10000>;
xlnx,depth = <0x400>;
xlnx,dwidth = <0x10>;
xlnx,num-channels = <0x1>;
misc_clk_0: misc_clk_0 {
#clock-cells = <0>;
clock-frequency = <12288135>;
compatible = "fixed-clock";
Observer ccasanova
Re: I2S transmitter and I2S receiver with petalinux
Hi all,
The solution is:
For I2S to  work on Linux platform, also we need an audio formatter IP along with I2S, not only I2s receiver and transmitter.
Thanks @florentw  for your support.
Observer ccasanova
Any answer?
HI @ccasanova
It is hard to say without knowing what changes you have done in the HW.
You might need to go throuygh each properties and see if you changed which can change them.
It is hard to give you a better answer without more information
Observer ccasanova
Hi @florentw,
I dont understand what exactly you need.
I dont have any change in the HW, I only need an external I2S output from ZYNQ 7010, that in the linux side it must be an ALSA device.
All the IP block have the default properties.
Have you got any VIVADO project that i can use it to generate a Petalinux, that an I2S transmitter it will detected as an ALSA device?
Hi @ccasanova
I was confuse with your message "Is it necesarry to modify the device tree with some change after the hardware definition in Vivado 2019?".
For what I understood is that you had a working design and then you modified the HW so you were asking if you had to do any change in the DT after that.
No I do not have a design with audio. What did you get from petalinux? I see that the i2S transmitter is in the device tree generator so I would assume you can use the petalinux flow for this. The device tree shoulkd be automatically generated
Observer ccasanova
@florentw,
Sorry for the understood.
I have made a new design only for testing I2S transmitter. I have generated bitstream and the hardware definition in VIVADO 2019. Then I use both  for generating a petalinux distribution, modyfing the options in the kernel like is wrote in XILINK wiki.
The device tree i've attached is the one that petalinux generated. But Linux doesnt "see" the I2S trasnmitter like an ALSA device. I cant use it from linux.
Note: The same Vivado project used in a baremeetal project works well.
Hi @ccasanova
Can you share you boot log? It might give us some tips about why linux cannot see the driver. Probalbly, the driver is not loaded properly due to some erros
Observer ccasanova
@florentw I've attached the boot log.
Hi @ccasanova
It seems that the driver is loaded. Do you see the IP under /dev?
Observer ccasanova
HI @florentw .
Under /dev i see this:
root@800:~# cd /dev
root@800:/dev# ls
block               loop4               mtd1ro              ram10               stderr              tty20               tty36               tty51               ttyPS0
char                loop5               mtd2                ram11               stdin               tty21               tty37               tty52               udev_network_queue
console             loop6               mtd2ro              ram12               stdout              tty22               tty38               tty53               urandom
cpu_dma_latency     loop7               mtd3                ram13               tty                 tty23               tty39               tty54               vcs
disk                mem                 mtd3ro              ram14               tty0                tty24               tty4                tty55               vcs1
fd                  memory_bandwidth    mtdblock0           ram15               tty1                tty25               tty40               tty56               vcsa
full                mmcblk0             mtdblock1           ram2                tty10               tty26               tty41               tty57               vcsa1
gpiochip0           mmcblk0p1           mtdblock2           ram3                tty11               tty27               tty42               tty58               vcsu
iio:device0         mmcblk1             mtdblock3           ram4                tty12               tty28               tty43               tty59               vcsu1
initctl             mmcblk1boot0        network_latency     ram5                tty13               tty29               tty44               tty6                vga_arbiter
kmsg                mmcblk1boot1        network_throughput  ram6                tty14               tty3                tty45               tty60               watchdog
log                 mmcblk1p1           null                ram7                tty15               tty30               tty46               tty61               watchdog0
loop-control        mmcblk1rpmb         port                ram8                tty16               tty31               tty47               tty62               zero
loop0               mtab                ptmx                ram9                tty17               tty32               tty48               tty63
loop1               mtd0                pts                 random              tty18               tty33               tty49               tty7
loop2               mtd0ro              ram0                shm                 tty19               tty34               tty5                tty8
loop3               mtd1                ram1                snd                 tty2                tty35               tty50               tty9
root@800:/dev#
And under /proc/device-tree i see:
root@800:/dev# cd /proc
root@800:/proc# cd device-tree
root@800:/proc/device-tree# ls
#address-cells  aliases         amba_pl         compatible      fixedregulator  memory          phy0
#size-cells     amba            chosen          cpus            fpga-full       name            pmu@f8891000
root@800:/proc/device-tree# cd amba_pl/
root@800:/proc/device-tree/amba_pl# ls
#address-cells            compatible                i2s_transmitter@43c10000  ranges
#size-cells               i2s_receiver@43c00000     name
Hi @ccasanova
Ok so it seems to confirm that the device is here.
what did you do to test it. did you run the following command?
aplay -D hw:0,0 -f S32_LE -r 48000 -c 2 ./test.wav
Observer ccasanova
Hi, @florentw
I've tryed and the result is there is no soundcard in Linux.
root@800:~# aplay -D hw:0,0 -f S32_LE -r 48000 -c 2 ./test.wav
ALSA lib ../../../alsa-lib-1.1.6/src/pcm/pcm_hw.c:1820:(_snd_pcm_hw_open) Invalid value for card
aplay: main:828: audio open error: No such file or directory
root@800:~# aplay -l
aplay: device_list:272: no soundcards found...
root@800:~
Hi @ccasanova
You tried
aplay -l
But can you try
aplay -L
I am not sure if there will be a difference but I am running out of idea of what to try...
Observer ccasanova
Hi @florentw,
The result is:
root@800:~# aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
root@800:~#
Maybe I've to add in the device tree a new sound card using the IP? I dont have more ideas. The steps in the wiki don't work.
Observer ccasanova
@florentw
Any new idea about this topic?
Hi @ccasanova
From what I can see from the drivers support page, only ZynqMPSoC is supported. Maybe the driver is not supporting Zynq-7000...
I do not have a design on Zynq-7000 I can check with
Observer ccasanova
Hello @florentw ,
Do you have contact with the two authors (xilinx employers) of the Linux driver?
Maybe is easy to modify, could you ask them? I have analysed the code of the driver and i dont see where is the limitation for not to work in a ZYNQ 7000 device.
Observer ccasanova
Hi all,
The solution is:
Hi @ccasanova
Thank you for sharing
Observer marode
Hi @ccasanova ,
could you please share a screenshot of your block design? I am struggling with the same issue.
Thank you.
