Visitor manb
IP Core DP1.4
Hello
We are currently evaluating options to incorporate Display Port1.4 IP core on Xilinx platform for our upcoming project.
Pls let us know the costing details of this IP core. Is the cost depands on its configuration.?
Manish
Re: IP Core DP1.4
Hello Manish @manb,
Please contact your FAE for the pricing information.
The cost of the core will be the same whatever the configuration of the core itself exctept if you need HDCP or DSC.
Just note that if you need Data Stream Compression (DSC) it is done by our partner Hardent, so you might need to pay separate fee. Also if you need HDCP you might need an extra. But you might need to confirm this with your FAE.
Florent
Visitor manb
Re: IP Core DP1.4/DP1.2
Hello
Thanks for your feedback.
I found that Zynq-7000 SoC transreceivers supports up to 12.5 Gb/s data rates and this family also supports DP1.2 IP .
My question is how it can support DP1.2 HBR2 speed.? In specificaton of DP1.2 it can go 17.28Gb/s in HBR2 mode.
Manish
Hi @manb,
In the DP spec you can do maximum 5.4Gbps/per lane which is way under the max of the GTs (12.5 as you said).
As you can have for lane, you can do up to 21.6 Gbps (5.4 Gbps). As on DP it is 8b/10b encoded, the "usable" bandwidth is 17.28Gbps (21.6*80%).
Thus yes, the DP1.2 core supports HBR2 on Zynq-7000 GTH.
Florent
Visitor manb
Hello
Thanks for this info.
Does IP core of DP1.2 support eDP?
Manish
Scholar watari
Hi @manb
What kind of features do you use ?
Unfortunetly, these IPs don't support eDP. They only support DP.
I already confirmed it.
However, I recommend to ask your FAE what you want to support eDP features.
Best regards,
HI @manb,
Do you have all the answers you needed?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Visitor manb
Yes
Issue is resolved. You can close it
