Implementing XAPP495 on atlys spartan 6...problem with HDMI out
Hi, I tried to implement xapp495 fixed from https://joelw.id.au/FPGA/DigilentAtlysResources#Improved_XAPP495
I added all files of DVI_test.v.... and the ucf file for DVI.... But when I uploaded to FPGA.... HDMI out is not showing the output.... Many people have such problem saying that it is an EDID problem... But XAPP495 fixed had resolved EDID problem... and there was no need of connecting JP6/JP7 jumpers...... Attached images will give you a clear picture on what I want to say....
Any kind of help would be appreciated a lot..... Thank you
Re: Implementing XAPP495 on atlys spartan 6...problem with HDMI out
Hi @silent.tears95,
You might want to try to add a chipscope inside your design to see where the data is stuck. I would start by ensuring the data is correctly getting inside the FPGA.
Hope that helps,
Florent
Florent
Hi @silent.tears95,
Hope that helps,
Florent
Florent
Thank you for your reply. It was a problem with the LCD, I changed the LCD and it started working... I used xapp495 fixed from joelw website..... Thank you very much
Hi @silent.tears95,
As your issue is fixed, please close the topic by marking a response as solution.
Thanks and Regards,
Florent
Florent
