Participant gmoore
Incorrect Clock Speeds in MIPI Rx Simulation
I am using the MIPI CSI-Rx Subsystem IP in a design for the Virtex VCU118 Ultrascale+ Board.
So far I am just running behavioural simulations and post-synthesis functional simulations, using a System Verilog CSI-2 model to generate the incoming MIPI packets. the line rate (for the 4-lANE design) is set at 1188Mbps.
This should mean a mipi clock rate of : 594Mhz (period 1.683ns) and an rx_byte_clk_clk rate of 148.5Mhz (period 6.734ns ).
It seems that the clock constraints defined in the .xdc files under the MIPI IP wrapper are not correct - file 'bd_45e0_phy_0_ooc.xdc' shows the phy clock rate as 1.5 gbps (period of 0.667ns).
Is there a way to over-ride these preferences ? I can see in the behavioural and post-synthesis simulations that the output phy clock is not the set 1188 rate, but the incorrect faster rate.
The .xci file and the xdc files are attached.
IP Version: MIPI CSI-2 Rx Subsystem 2.2 (Rev. 1)
OS: Linux
Vivado Version: 2017.2
Board/Part: XCVU9P-FLGA2104-2L-E
Re: Incorrect Clock Speeds in MIPI Rx Simulation
Hello @gmoore
For your usecase (UltraScale+ device , RX only IP with continuous clock-mode)
I don't think we have any critical issue. ( A few customer are using 2016.4 IP with similar usecase in their product without any issue)
But please notice that MIPI CSI-2 RX Subsystem and MIPI D-PHY IP has many improvement since 2017.2 release. (You can check the IP change log in the Vivado).
Since you are doing a new design, I do suggest to use the latest MIPI IP.
Please check this Answer record. https://www.xilinx.com/support/answers/71582.html
You will need to add  the following constraint if you are using MIPI IP from Vivado 2018.2 and previous version.
set_property DIFF_TERM_ADV TERM_100 [get_ports .... ]
Thanks & regards
Leo
Hello @gmoore
1500Mbps clock constraint is expected.
Note :
If you are using MIPI IP for UltraScale+ device, please use 2018.1 or newer IP version.
( IP from Vivado 2018.3 is recommended )
There is a critical issue in the older MIPI IP that your system may not work correctly with non-continous clock mode.
Thanks & regards
Leo
Participant gmoore
Hi Karnanl,
Thank you for the response. For compatibility reasons I would like to stay with my current version of the IP - in my case, I am using continuous clock mode - are there any known issues with using continuous clock mode in my current version of the IP ?
Hello @gmoore
Thanks & regards
Leo
Hi @gmoore,
Is everything clear for you? Was @karnanl's reply enough for you?
Thanks and Regards,
Participant gmoore
Apologies for the delayed response.
In my case, defining the actual constraints in the top-level constraints file over-rode the constraints which had been generated in the IP constraints file, and gave me the correct clock speeds.
You may close this ticket.
Hi @gmoore,
Could you kindly mark @karnanl's reply as accepted solution (click on accept as solution below the reply). We want to avoid Xilinx action on this and prefer when the user marks as solution ;)
