Visitor eshea
Initializing TPG
I am a beginner and I am trying to initialize the Test Pattern Generator but have not been able to successfully do so. My code keeps hanging when I call the function XV_tpg_IsReady(XV_tpg *InstancePtr) and I'm not sure why. Here is my code:
/***************************** Include Files *********************************/
#include "xparameters.h"
#include "xdebug.h"
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xv_tpg.h"
/******************** Constant Definitions **********************************/
#ifndef TESTAPP_GEN
#define TPG_DEVICE_ID     XPAR_V_TPG_0_DEVICE_ID
#endif
/************************** Function Prototypes ******************************/
int tpg_selftest(u16 DeviceId_tpg);
void tpg_init(void);
/************************** Variable Definitions *****************************/
XV_tpg tpg;
#ifndef TESTAPP_GEN
int main()
       int Status_tpg;
       init_platform();
       /* Configure TPG */
      Status_tpg = tpg_selftest(TPG_DEVICE_ID);
      if (Status_tpg != XST_SUCCESS)
              xil_printf("TPG config failed: Failed\r\n");
              return XST_FAILURE;
      xil_printf("TPG initialized\r\n");
      tpg_init();
      xil_printf("--- Exiting main() --- \r\n");
      return XST_SUCCESS;
      cleanup_platform();
      return 0;
#endif
      XV_tpg_Config *Config;
      int Status = XST_SUCCESS;
      Config = XV_tpg_LookupConfig(DeviceId_tpg);
      if (!Config)
              return XST_FAILURE;
      /* Initialize TPG */
     Status = XV_tpg_CfgInitialize(&tpg, Config, Config->BaseAddress);
     if (Status != XST_SUCCESS)
              return XST_FAILURE;
     return Status;
void tpg_init(void)
     int status_tpg_init = XST_SUCCESS;
     uint32_t height;
     uint32_t width;
     status_tpg_init = XV_tpg_IsReady(&tpg);
     xil_printf("Status %u\r\n",(unsigned int)status_tpg_init);
     status_tpg_init = XV_tpg_IsIdle(&tpg);
     XV_tpg_Set_height(&tpg, (u32)600);
     XV_tpg_Set_width(&tpg, (u32)800);
     height = XV_tpg_Get_height(&tpg);
     xil_printf("Height = %u\r\n",height);
     width = XV_tpg_Get_width(&tpg);
     xil_printf("Height = %u\r\n",width);
Re: Initializing TPG
Hi @eshea,
Could you share a screenshot of your BD?
Also you might need to start the TPG by writing to register AP CTRL (reg 0x0)
XV_tpg_WriteReg(tpg.Config.BaseAddress, XV_TPG_CTRL_ADDR_AP_CTRL, 0x81);
Or you might want to use the example design as a reference to start.
Hope that helps,
Florent
Florent
