Visitor espsea
Input TMDS IOSTANDARD to GT.
Im am currently implementing a FMC card for HDMI 1.4b input (RX) to a ZCU106. Is it correct that all you need to make the TMDS signals compliant with the GT is to add 50 ohm termination resistors? Read something about that the HDMI standard accept a larger variation than the GT tranceiver PLL is garanteed to be able to lock on. Does this mean that i should add a repeater/retimer on the clock or does this apply to all TMDS signals? Any thoughts around this?
Re: Input TMDS IOSTANDARD to GT.
Hi @espsea
ZCU106 has HDMI port, it doesn't need additional FMC card to work with HDMI. So you can refer to ZCU106 schematic.
If you want to design your own card at RX side, yes, you need to use external pull-up resistor(50 ohms), which is close to GT, to do the TMDS level shifting job.
For repeater/retimer (Ti TMDS181), it's required for HDMI 2.0 data rates. It helps to clean up signals. So you need it to pass the HDMI 2.0 compliance test.
Hi @espsea
Visitor espsea
Hi xud,
Thanks for the reply.
I should probably have mentioned that i will input two HDMI streams to the ZCU106 so i will use the HDMI port
on the card for one of the inputs and a FMC card for the other. However, i got the answer i was after, thanks alot.
