Observer ankitsohni
Interlace video compression capability in VCU(ZCU106)
Does video codec present in ZCU106 board supports for interlace video ?
As per Xilinx VCU TRD 2019.1 Wiki, VCU supports interlace video. For interlace video compression, what gst command should be run ?
In specific, I have PAL video input (720 x 576i @ 50fps). Is it possible to compress PAL video with VCU ?
Tags (2)
Re: Interlace video compression capability in VCU(ZCU106)
Hi @ankitsohni
You need to use the alternate parameter:
gst-launch-1.0 v4l2src io-mode=4 device=/dev/media0 ! video/x-raw,interlace-mode=alternate, format=NV16_10LE32, width=720, height=576,framerate=50 ! omxh265enc ! filesink location="tt.h265"
Florent
Hi @ankitsohni
Florent
Hi @ankitsohni
Do you have any update on this topic? Is everything clear for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Observer ankitsohni
Thanks for the response.
I have not yet checked & verified this command as we are arranging PAL to SDI convertor at our end. Since ZCU106 board takes only SDI input.
I will update soon on this solution.
interlace video support feature of VCU is available on 2018.3 VCU TRD images ?
Ankit Sohni
HI @ankitsohni
No I do not think the VCU TRD fully support interlaced yet.
Florent
HI @ankitsohni
Is everything clear for you on this topic?
Thanks and Regards,
Florent
Observer ankitsohni
I have tried the command in ZCU106 Board, but pipeline got broken. Please see the log attached here :-
root@zcu106_vcu_trd:~# gst-launch-1.0 v4l2src io-mode=4 device=/dev/media0 ! video/x-raw,interlace-mode=alternate, format=NV16_10LE32, width=720, height=576,framerate=50 ! omxh265enc ! filesink location="tt.h265"
WARNING: erroneous pipeline: could not link v4l2src0 to omxh265enc-omxh265enc0, neither element can handle caps video/x-raw, interlace-mode=(string)alternate, format=(string)NV16_10LE32, width=(int)720, height=(int)576, framerate=(int)50
But this command works out for me
gst-launch-1.0 v4l2src io-mode=4 device=/dev/video0 ! video/x-raw, format=NV12, width=720, height=288,framerate=50/1 ! omxh265enc ! h265parse ! omxh265dec ! queue max-size-bytes=0 ! kmssink bus-id="a0070000.v_mix"
Whether this command treats as progressive before processing ?
Hi @ankitsohni
Interlaced is not fully supported in the VCU TRD 2019.1. My guess is that the SDI RX is not properly setting everything as interlaced.
It should be better in the next version.
Florent
