Is there degradation in quality with video scaler scaling factor > 0.5?
Is there degradation in quality with Xilinx video scaler,scaling factor > 0.5?
We want to convert from 2592*1944 to 1440*1080. Scaling factor , Horizontal SF =  0.5559 (2592/1440) , Vertical SF = 1080 / 1944 = 0.5555.
We are observing some degradation in quality of output image . Also sharpness is missing in the image .
If we reduce the scaling factor to 'less than or equal to' 0.5 , will there be any improvement in quality ?
[To reduce the scaling factor either we need to increase input resolution(not possible in our case) or need to decrease the output resolution]
Re: Is there degradation in quality with video scaler scaling factor > 0.5?
it should not be
share input and output image
which version of IP you are using
Thanks and Regards
Balkrishan
Thanks for the reply.
The version of scaler IP I am using is 8.1.
I can share the output image . But , first thing i need to know is ,
What is the dependency of scaling factor on quality of image ?
Which scaling factor is better ? >0.5 or <0.5 or = 0.5.
Your output image has about 70% fewer pixels than your input image, so obviously you'll be losing a lot of fine detail. Larger scaling factors (closer to 1) mean that there's more information available in the output image, so less information has to be thrown away.
According to you larger scaling factors only give better result :
Say , For input resolution 2592*1944 ,
Output resolution 1920 * 1080 (HSF = 0.74 , VSF = 0.555 ) gives better result than 1440 * 1080 (HSF = 0.555 , VSF = 0.555) and 1280*720 (HSF = 0.4938 , VSF = 0.666)  , right ?
