Issues Supporting 2 SDI Video Inputs
Hello Xilinx Forums,
I am developing on a custom board and trying to support 2 SDI inputs. I have successfully implemented the TRD and now adding the second SDI input. I am at the stage where I have both SDI rx SS operational, however, I am receiving video lock/unlock interrupts whenever I have both inputs plugged in. Both SDI rx SS's do not share the same interrupt and the both have their own respective drivers. Both SDI inputs reside on the same transciever bank, and same reference clock.
I have tested both SDI inputs individually and see no issues. Could I have a crosstalking issue or configuration issue?
Thank you.
Re: Issues Supporting 2 SDI Video Inputs
Hi I am doing something similar at the moment with 4 SDI rx chains. I also get continuous interrupts generated with loss lock when I have it running the SDI_Rx example firmware. I have been trying to debug it and I don't see my GT IP losing lock. I observed it's the UHD SD Rx subsystem generating loss off lock. Narrowing down I find they the SMPTE detect stream format register changes often with the same SDI video. I will watch this space if anyone knows.
regards
bade
Hello @jchewpoc
Is this a system with OS(built using petalinux) or its a standalone system?
What is the device on which you are testing this?
Can we have a quick look into your block design? if you can share with us completely populated BD saved as BD would be helpful to comment further.
Kunal
Hello @kvasantr ,
I am using buildroot to build my kernel OS, however, I am using Xilinx's linux 2019.1 branch on git. A quick update, I did get the 2 channel SDI inputs working on another custom development board I have, that has a different pinout. I do not believe it is a block design issue anymore, and it is most likely a hardware issue. Any recommendations on good high speed video design practices or video guidelines you can share?
Thank you.
Hi @jchewpoc
To debug issues related to the UHD-SDI RX Subsystem you might want to follow the debugging section of PG290
Also this xapp can help looking at the GTs element (draw an eye diagram, check the PLL lock status...): xapp1295
Florent
