Issues with H.264/H.265 Video Codec Unit Out of Box Example 1
I refer to https://www.xilinx.com/support/documentation/ip_documentation/vcu/v1_1/pg252-vcu.pdf
I would like to transfer the sample files from my computer to my Zynq MPSOC ZCU104.
According to step 2, How to copy the downloaded sample files to /home/root partition of the board?
Re: Issues with H.264/H.265 Video Codec Unit Out of Box Example 1
Hi @sdsocdso1 ,
If your board can access internet, you can just use the wget command from the ZCU104.
If not, what I usually do is download the file on the host machine, copy into the SDCard. Then on the ZCU104, mount the SDCard and use the file.
Florent
Hi @sdsocdso1 ,
Florent
Hi @florentw ,
Thanks for your reply.
My board cannot access the internet.
Could you help me by showing the steps in including the file to the /home/root of SD card?
I copied the file to the SD Card, but when I boot ZCU104 board, I cannot locate the file in /home/root.
How do I mount the SDCard and use the file?
HI @sdsocdso1 ,
This is general linux knowledge.
Find the name of your SDcard (/dev/sdX)
sudo fdisk -l
Then create a mount point:
mkdir /mnt/sdcard
The mount the sdcard
sudo mount /dev/sdc1 /mnt/sdcard
Then you will be able to access the content of the SDcard is /mnt/sdcard from the root partition
Florent
Mentor
Mentor
Hi @sdsocdso1
Here is additional information for you.
After mount and copy, you must execute the following command on except this mount directory.
$ sudo umount /mnt/sdcard
After this command, you can safty eject sd card.
Best regards,
Hi @sdsocdso1 ,
Do you need any more help on this topic?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
