Observer hakyemez
Latency of Encoders
Could you help me to compare the latency of HEVC and AVC for encoding in Zynq Ultrascale+ VCU IP. In PG252 16.6ms is mentioned for encoder latency. In which options that latency is measured? How much latency does 'Using encoder buffer' option add to the system?
Kind Regards,
Tags (2)
Re: Latency of Encoders
The number in the Product Guide PG252 are independent of the encoder mode.
If you want to do additional testing you can use gst-shark as noted in Debugging Performance Issues sub-section of section Debugging a VCU based System.  You can find example of how to use gst-shark to measure latency on Google.
Chris
Video Design Hub | Embedded SW Support
Hi @hakyemez,
Do you have any updates on this? Was @chrisar's reply enough for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
Observer hakyemez
Hi Chris,
I've downloaded Zynq UltraScale+ MPSoC VCU TRD design application on ZCU106 from that source :
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842306/Zynq+UltraScale+MPSoC+VCU+TRD+2018.2+ +Design+Module+1#ZynqUltraScale%EF%BC%8BMPSoCVCUTRD2018.2-DesignModule1-1.3.6VCUGSTAPP
There are prebuild design sources and I've tried to find the latency of encoder with using gst-shark tool as you've suggested.
GST_DEBUG="GST_TRACER:7" GST_TRACERS="interlatency" vcu_gst_app /media/card/config/1080p60/Record/1080p60_HEVC_LOW.cfg
I got that results for interlatency :
0:06:56.034102613 2514 0x3793ea80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)capsfilter1_src, time=(string)0:00:01.681336445;
0:06:56.034149828 2514 0x7fa8004cf0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)omxh265enc-omxh265enc0_src, time=(string)0:00:00.674996550;
0:06:56.034258508 2514 0x7fa8004cf0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)omxh265enc-omxh265enc0_src, time=(string)0:00:00.674997150;
0:06:56.034315054 2514 0x3793ea80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)h265parse0_src, time=(string)0:00:01.681547666;
0:06:56.034382431 2514 0x3793ea80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)qtmux0_src, time=(string)0:00:01.681615653;
0:06:56.034423835 2514 0x3793ea80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)filesink0_sink, time=(string)0:00:01.681615653;
0:06:56.036735266 2514 0x3793ea80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)queue1_src, time=(string)0:00:01.683847346;
0:06:56.036791182 2514 0x3793e9e0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)capsfilter0_src, time=(string)0:00:00.325885619;
0:06:56.036814964 2514 0x3793ea80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)capsfilter1_src, time=(string)0:00:01.683936885;
0:06:56.036990232 2514 0x3793e9e0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)capsfilter0_src, time=(string)0:00:00.000038984;
0:06:56.037078340 2514 0x3793ea80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)h265parse0_src, time=(string)0:00:01.684199021;
0:06:56.037101853 2514 0x3793e9e0 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)capsfilter0_src, time=(string)0:00:00.000025733;
0:06:56.037150958 2514 0x3793ea80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)qtmux0_src, time=(string)0:00:01.684272259;
0:06:56.037192392 2514 0x3793ea80 TRACE GST_TRACER :0:: interlatency, from_pad=(string)v4l2src0_src, to_pad=(string)filesink0_sink, time=(string)0:00:01.684272259;
Is the latency of H265 encoder calculated this way ?
interlatency of  [v4l2src0_src to qtmux0_src] -  interlatency of [v4l2src0_src to h265parse0_src]
1.681615653 - 1.681547666 = 67 us
Kind Regards,
Serkan Ender Hakyemez
