Visitor ramanar
LogiCORE IP Video PHY Controller v2.2 question
PG230 (December 5, 2018) indicates on page 5 that
<quote>
The Video PHY Controller does not support standalone usage.
</quote>
Is there any possible way to use this with a non-Xilinx DisplayPort Link Layer controller? What feature support is missing in the IP, that is preventing its use along with an external (non-Xilinx) Link Layer controller?
Re: LogiCORE IP Video PHY Controller v2.2 question
Hi @ramanar,
The Video PHY Controller was developed specifically to work with either the Xilinx DisplayPort IP or the HDMI IP.
This means that interface and control are specific to these IPs and because this is not supported in a standalone usage, we do not document the PHY controller to the level needed to interface to another IP.
-Sam
Xilinx Video Design Hub
Hi @ramanar,
-Sam
HI @ramanar,
Was @samk's reply enough for you?
Thanks and Regards,
Visitor ramanar
I don't see a button labeled "Accept as solution"
Hi @ramanar,
As we had no reply from you and we believed we provided the correct answer, the reply was accepted as solution for you.
Note that even if we have the ability to mark as accepted solution, we prefer the user to mark as solution to make sure everything is clear
