Visitor cosmonayt
MCode block ports problem
Hello, everyone ! Could you please help with some problem.
I'm trying to make Simple Detector example from System Generator User Guide. I created a function file for MCode block with following code
function z = xlmax(x, y)
if x > y
z = x;
else
z = y;
end
But after applying this function to MCode block in Simulink model block's input and output ports just vanished ! So I cant wire other block to it. There is no error report or something. Function m-file and model file are in the same directory. I'm working in MATLAB 2013b and System Generator from Vivado Design Suite 14.3. Please, help.
Re: MCode block ports problem
Do you see the issue with other examples too.
Try below steps
1.Create the M file file save in the directory and then just create a new model and add Mcode Block it should detect the m file and should show the inputs and out ports.
2.If one doesn't work,trying clearing cache,closing matlab and repeat the above steps in a different directory and check if there is any issue with the path of directory.
Satish
Try below steps
Satish
Visitor cosmonayt
Thanks a lot ! It seems that cache clearing was useful.
