MIPI Bitslice Control Delay
I was wondering if we could have more information about how delay tuning is done on the MIPI block with Ultrascale+ devices when using the MIPI RX subsystem.
  1. Is this done automatically by the block?
  2. Do we have to add any additional constraints with known delays from our PCB boards?
  3. How much delay can be compensated?
  4. Can both positive and negative delays relative to the clock be compensated?
Thanks!
Mark
Tags (2)
Re: MIPI Bitslice Control Delay
Hello Mark
>Theoretically, there should be a way to specify the boot up settings for the BITSLICE CONTROL on a per interface setting correct?
User will not be able to set custom delay using taps in the bitslice control.
MIPI D-PHY IP will "train" each line automatically every LP --> HS transition, so each data lane will be sampled correctly.
Thanks & regards
Leo
Hello Mark @markramona
Yes.
No, not necessary.
If the delay is within range mentioned by the spec, it can be compensated and already tested.
Note :
Delay between clock and any data lane should be less than UI/50 for all line-rates.
Please also ensure that RX Setup/Hold requirement is not violated.
Yes, both can be compensated.
Thanks & regards
Leo
Hi @karnanl
That is super helpful!
Thanks!
What is the document that you referred to? I would like to take some to read it in depth.
We might have up to UI/30 of static delay in our system. Do you have a reference on how we can designs constraints that take this amount of delay into account?
Thanks!
This is taken from mipi_D-PHY_specification_v1-1.pdf
-- You can download this document from (https://members.mipi.org/wg/All-Members/document/folder/8354)
   You can download for free, if you company is mipi.org member.
Hmm, pardon me but I do not have the answer.
1. I would suggest you to fix your board to follow MIPI spec.
2. I do see that some customer boards working without any issue with static delay larger than UI/50. (~20ps delay for 1500Mbps line-rate), but we cannot guarantee that the same number will achievable on your board.
Thanks & regards
Leo
Hi Leo,
Thank you for the fast response.
That all makes sense. We will keep it in mind for future iterations of our design.
Hi @markramona,
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Aoife
It is hard to say if the question has been "answered" or not.
I would say the question has been half answered.
Yes we were able to define some bounds under which the MIPI signal would be correctly captured by the FPGA using the IP, but I'm still unclear about how to customize the the delay using the taps in the bitslice control is still unclear.
Hello Mark
Thanks & regards
Leo
Awesome, thanks, for the quick response.
Taking this into account it seems that while the MIPI spec requires lines to be matched to UI/50, there should be some slack due to the training that is possible on every LP -> HS transitions.
