MIPI CSI -2 DPHY HS mode
On K7 family series:-
1. Low power state (LPS) insertion between the packets. What's the fashion of the transition for the High-SPeed mode?
LP00->LP01->LP11
2. In pg:no27 of pg260-MIPI-csi2-tx transition LP11 is explaining what?
3. We want CSI-2 DPhy in High-Speed mode what are the transitions initially the controller generates to CSI-2 Rx in regards the LP to HS?
4. Does CSI Tx packetizes 8 bits into a byte?
5. What is the data word for YUV_422 like RGB888 has 0x24?
Prasanna Kumar Daram
Re: MIPI CSI -2 DPHY HS mode
Hello Prasanna @daram123
Some of your questions are regarding MIPI protocol specification. Could you please take sometime to read these.
For MIPI D-PHY specification please check: https://members.mipi.org/wg/All-Members/document/folder/8358
For MIPI CSI-2 specification please check : https://members.mipi.org/wg/All-Members/document/folder/8367
MIPI starts from LP mode, to change to HS mode, we have the following transition for both clock/data lanes.
LP11-->LP01->LP00->HS
I do not understand this question.
I cannot find LP11 keyword in page 27.
https://www.xilinx.com/support/documentation/ip_documentation/mipi_csi2_tx_subsystem/v2_0/pg260-mipi-csi2-tx.pdf
(a) ensure all clocks are stable
(b) Follow reset sequence mentioned in PG260 Figure 3-4.
(c) set core enable.
(d) put pixel data into AXI4-stream input I/F (recommend to use AXI4-stream I/F instead of Native interface)
For details see PG260 chapter3.
Yes
Hmm, I believe you are asking for Data type.
For YUV422 8 bit, Data type=0x1E. (This is mentioned in CSI-2 specification Chapter11)
Thanks  & regards
Leo
Yes
Thanks  & regards
Leo
@karnanl
>HS has a 400mv range and LP has a 1.2V after HS does the transition occurs on the pins of HS mode?
FPGA has LVDS pins. Do they support 1.2V and 400 mV and also the transitions?
CSI -2 Tx generates the transitions?
Is "10"&x"4" same as x"24"?
Prasanna Daram
Hello Prasanna Kumar @daram123
(Answer is no)
Opps, it seems you are using 7-series devices. We do highly recommended to use US+ devices (any model) for MIPI I/F.
7-series device does not have I/O that support MIPI D-PHY natively. If you want to use  7-series you will need to use external PHY device (for example device from Meticom).
Yes.
MIPI CSI-2 TX Subsystem has MIPI D-PHY TX IP inside. MIPI D-PHY TX IP responsible to generate LP->HS, HS->LP transition.
>is "10"&x"4" same as x"24"?
Pardon me, I do not understand this question.
Thanks & regards
Leo
@karnanlK7 and FPGA D-PHY generate the transitions. to Pass it forward to external devices we need Meticom MC20902. Does this setup carry the transitions of LP->HS and HS->LP?
Prasanna Daram
Hi @daram123
As per my knowledge, Answer is yes.
For more information check xapp894-d-phy-solutions.pdf (Specifically  Page18~20)
Bhushan
Bhushan
@karnanl The word count for RGB888 1920x1080p60 is x"1680". What it is in a Dual Pixel per beat?
Prasanna Daram
Hello @daram123
1. Word count = 1920 pixel x 3 byte = 5760 (dec) = 0x1680. This is the number of byte in 1 HS packet.
    Details explanation can be found in MIPI CSI-2 specification
2. Same answer for Dual pixel per beat.
     SInce the word count does not change.
Hope this helps.
Thanks & regards
Leo
Hello @bpatil>>
The XAPP Dphy doesn't specify the METICOM MC20902 GPIO lines, to be set to MIPI Dphy or LVDS to SLVS conversion. pg-no 4 in this document gives enough details for METICOM Conversion.
Prasanna Daram
