Participant egorman44
MIPI CSI-2 Receiver Subsystem IP core simulation in INCISIVE with evaluation license
Hello guys. I have an evaluation license  for MIPI CSI-2 Receiver Subsys Xilinx IP. According to UG900 I compiled simulation library and pointed Vivado where these libraries are located. Then I chose Incisive Simulator as a target simulator and run behavioral simulation. IES  gave a following error during elaboration:
ncelab: *E,CUVMUR (/dsi_csi_sim/dsi_csi_sim.srcs/sources_1/ip/mipi_csi2_rx_subsystem_0/bd_0/hdl/bd_639e_0.v,361|26): instance '{*Name Protected*}' of design unit '{*Name Protected*}' is unresolved in '{*Name Protected*}.{*Name Protected*}:{*Name Protected*}'.
ncelab: *N,CUVPRO: For the above CUVMUR error message, the problem occurred in module declared in file /xilinx/Vivado/2017.2/data/ip/xilinx/mipi_csi2_rx_ctrl_v1_0/hdl/mipi_csi2_rx_ctrl_v1_0_rfs.v.
  bd_639e_0_r_sync_0 r_sync
On the other hand I tried to load Xilinx D-Phy IP and Xilinx 10G-BASE-R IP with included licenses. Both were compiled succesfully and Incisive loaded their snapshots.
What could be the reason why MIPI CSI-2 Receiver IP doesn't loaded into Incisive ? Could it be possible because of evaluation license ?
Re: MIPI CSI-2 Receiver Subsystem IP core simulation in INCISIVE with evaluation license
Hi @egorman44,
What vivado version are you using? Could you first make sure that you are using the supported version of Incisive (look at UG973 for your vivado version).
I would expect the simulation to work with a evaluation license...(I am not licensing expert though)
Florent
Florent
Hi @egorman44,
Florent
Florent
 florentw thank you a lot for reply. In ug973 I found that Vivado 2017.2 is not compatible with my previous IES version. When I change IUS version for newer one it starts to launch simulation !
