MIPI CSI-2 Rx SS 300MHz IDELAYCTRL clk critical warning when sharing bank
Setup:
  Kintex 7 Speed grade 3
  Vivado 18.3
  MIPI Line Rate: 1500 Mbps
  I have 2 MIPI CSI-2 RX Subsys in a single HP bank.  Both MIPI need to input at 1500MBps but from different sensors.  I configured:
    1st MIPI IP
      "Include IDELAYCTRL in core" = TRUE
      "Enable 300 MHz clock for IDELAYCTRL" = TRUE
    2nd MIPI IP
      "Include IDELAYCTRL in core" = FALSE
      "Enable 300 MHz clock for IDELAYCTRL"  does not appear
For the 2nd IP, clk_300m input does not appear.
The design passes "Generate bitstream".  But I get critical warning:
  • [Timing 38-469] The REFCLK pin of IDELAYCTRL bd_i/mipi_0/inst/phy/inst/inst/bd_16a5_phy_0_rx_support_i/slave_rx.bd_16a5_phy_0_rx_phy_i/gen_idlyctrl_core.delayctrl has a clock period of 3.333 ns (frequency 300.030 Mhz) but IDELAYE2 bd_i/mipi_csi2_rx_subsyst_0/inst/phy/inst/inst/bd_d664_phy_0_rx_support_i/slave_rx.bd_d664_phy_0_rx_phy_i/mipi_dphy_v4_1_2_rx0_inst/idelay_cm has REFCLK_FREQUENCY of 200.000 Mhz (period 5.000 ns). The IDELAYCTRL REFCLK pin frequency must match the IDELAYE2 REFCLK_FREQUENCY property.
Will this cause any problem?  Is there a walkaround if it does?
Neo
Tags (2)
Re: MIPI CSI-2 Rx SS 300MHz IDELAYCTRL clk critical warning when sharing bank
Hello wtneo@leica
Which Calibration mode you are using?
Please share your xci of your IP.
Please check following notes from PG232 carefully:
Please let us know your end goal and application details.
Bhushan
Hi Bhusan,
  My settings:
    MIPI 0
      "Include IDELAYCTRL in core" = true
      "IODELAY_GROUP Name" = mipi_idly_group_0
      "Calibration mode" = AUTO
      "Enable 300 MHz clock for IDELAYCTRL" = true
    MIPI 1
      "Include IDELAYCTRL in core" = false
      "Enable 300 MHz clock for IDELAYCTRL" = unable to select once "Include IDELAYCTRL in core" = false
Finally I have connected MIPI 0 output port dlyctrl_rdy_out to MIPI 1 input port dlyctrl_rdy_in.
My setup have met all the conditions you highlighted.
I tried to attach XCI file but got these error messages when I post reply:
The attachment's bd_mipi_csi2_rx_subsyst_0_0.xci content type (application/octet-stream) does not match its file extension and has been removed.
The attachment's bd_mipi_csi2_rx_subsyst_0_1.xci content type (application/octet-stream) does not match its file extension and has been removed.
So I change extension to TXT, zipped and attached.
Hello wtneo@leica
Your MIPI CSI-2 RX IP settings seems to be correct.
Is it possible for you to provide test case design for reproducing this issue at our end?
or Share block diagram and constraints of your test case design?
Bhushan
  I have create a simple project that exhibits the same warning.  I have attached tcl file to recreate project in Vivado 18.3.
  The warning I am seeing is:
[Timing 38-469] The REFCLK pin of IDELAYCTRL bd_i/mipi_0/inst/phy/inst/inst/bd_5048_phy_0_rx_support_i/slave_rx.bd_5048_phy_0_rx_phy_i/gen_idlyctrl_core.delayctrl has a clock period of 3.333 ns (frequency 300.030 Mhz) but IDELAYE2 bd_i/mipi_1/inst/phy/inst/inst/bd_9019_phy_0_rx_support_i/slave_rx.bd_9019_phy_0_rx_phy_i/mipi_dphy_v4_1_2_rx0_inst/loop0[3].idelay_s has REFCLK_FREQUENCY of 200.000 Mhz (period 5.000 ns). The IDELAYCTRL REFCLK pin frequency must match the IDELAYE2 REFCLK_FREQUENCY property.
Pls advise will this warning cause malfunction in MIPI core, OR the delay tuning is not affected by this warning.
Pls advise if I can use 200MHz ref clk for IDELAYCTRL when MIPI datarate is 1500Mbps, and it will work just fine.
Hello wtneo@leica
Please use 200MHz clock for IDELAYCTRL , It will working just fine.
Thank you,
Leo
Hello wtneo@leica
I tried to run your demo tcl file with Vivado 2018.3 but it failed with error:
ERROR: [Vivado 12-172] File or Directory 'C:/v183_k7_demo/v183_k7_demo.srcs/sources_1/bd/bd/hdl/bd_wrapper.v' does not exist
Bhushan
Hi Bhushan,
  Hmm I thought the TCL script will regenerate that automatically.
  So here it is.
Hi Leo,
  Ok tks.  Meanwhile I will try to see if any way to get 300MHz to work.
Neo
Hello wtneo@leica
I have downloaded bd_wrapper.v file. After running TCL script, now I am getting issue for top.xdc file missing.
I believe this source(s) files (bd_wrapper.v and top.xdc) were local or imported into the original project, so they were missing.
Bhushan
