MIPI CSI-2 on Zedboard?
I have a Zedboard with a FMC-105-DEBUG board. I would like to process MIPI CSI-2 data of a low-resolution camera over this setup and was wondering how (or if) this can be done?
Xilinx is offering the "MIPI CSI Controller Subsystem" , but the page says that the board needs Xilinx UltraScale+ which the Zedboard does not seem to have. Can this still be done or is there another way?
Thank you for any suggestions.
Re: MIPI CSI-2 on Zedboard?
Hi arasch.lagies@ams.com,
You can use the MIPI CSI2 Subsystem IPs (RX/TX) however you need an external phy (while the US+ devices have an integrated D-PHY termination) as per the MIPI CSI controller subsystems page you are referring:
"Xilinx 7-series devices require external D-PHY bridges or passive components to implement D-PHY layer".
For more information about the D-PHY solutions on 7-series, please refer to xapp894. We recommend to use a resistor network or an external PHY (meticom). So I am not sure you will be able to use directly the  FMC-105-DEBUG board.
Hope that helps,
Florent
Hope that helps,
Florent
Thanks for your suggestion, @florentw
