Observer ibrahimsangi
MIPI D-Phy Hack
I am trying to connect the MIPI 2 lane camera. And camera D-phy is configured to use
M5 as clock
L2 as Data[0]
L4 as Data[1]
But the problem is, in my hardware the L4 pair is not routed to the camera. instead there is another pair from same bank65 is routed to data[1] which is J5.
Is it possible that we can configure J5 seperately as differential pair input pins and connect that pair back to L4 internally FPGA. This could save us a lot.
I don't want to do an external rework on FPGA. If we can connect L4 to J5 and L3 to H5 internally in FPGA that would be great.
thanks
Re: MIPI D-Phy Hack
Well, it is working with different pin assignments. I had to swap all of them.
J5 Clock,
M5 Data[0]
L2 Data[1]
I successfully generated and tested this configuration. Which worked for us.
Thank you.
Re: MIPI D-Phy Hack
Hello Ibrahim @ibrahimsangi
I don't think this is possible.
All you need to do is to re-open your MIPI CSI-2 RX Subsystem GUI, and set the new pin-assigment setting, and re-do Vivado implementation.
I do not know what device-model you are using, but since L4 and J5 are in the same bank, this pin-assignment modification is possible.
1. If L4 and J5 are in the same-byte, you can use your current clock-pin (M5).
2. If L4 and J5 are in different-byte, Please ensure that your current clock-pin (M5) is a QBC(Quad-Byte-Clock) pin not DBC pin. Pleasere-run Vivado Implementation to check if your new pin-assignment is good.
Thanks & regards
Leo
Re: MIPI D-Phy Hack
Hi @ibrahimsangi
Do you have any update on this? Was @karnanl 's reply enough for you?
Thanks and Regards,
Re: MIPI D-Phy Hack
J5 Clock,
M5 Data[0]
L2 Data[1]
Thank you.
