MIPI_DPHY RX SIM_MODEL behavior error
problem:
Mipi-dphy rx: 1 diff clk;4 diff data.
When diff data rate is 185.65Mbpsper laneDDR, Mipi-dphy RX sim model can recive data correct; When diff data rate is 594Mbpsper laneDDR, Mipi-dphy RX sim model recive data error,cannot recongnize frame header fail(data package error) ;
What’s problem
ZCU 102
Vivado vision2017.3
MIPI-DPH vision4.0
MIPI-DPHY config
sim_model file:
Re: MIPI_DPHY RX SIM_MODEL behavior error
Hello @taylor91
1. This issue will affect both sim and HW.
2. Looking at your sim error message
    It seems that your simulation including Xilinx protected modules (secureip) with .vp extension,  I believe the module contents were non-accessible for 3rd party simulator directly.
3. Vivado support 3rd party simulator using , it can be run from Vivado window.
Please see also UG900 Chapter 1~3  https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug900-vivado-logic-simulation.pdf
It mentioned basic step how to launch simulation using Vivado GUI. Suggest you to follow this for first time trial.
It would be better if you can start simulation from Example Design.
Vivado will generate a script to launch the simulation,  so you can check the script to find if you have missed some important file.
Please note that we should pre-compile simulation libraries for 3rd party simulator.
Usually if there is no compiled simulation libraries available, simulation will not run.
Thanks & regards
Leo
Hello @taylor91
Are you using the same IP setting (Line-rate 1000Mbps) to receive multiple line-rate usecase ( for ex: 594Mbps and 185.65 Mbps ) ??
If, Yes.
This is not a  supported usecase.
Hope this helps.
Leo
i change  the  data rate  to 594Mbps,also  has  the   problem.sim  include cell:
sim  wave(cannot  get  frame  header):
Hello @taylor91
This is a MIPI D-PHY IP bug , and already fixed in 2018.3.
Could you please migrate to Vivado 2018.3 or later version, and redo the simulation ?
Leo
Just a sim bug? if i use this dphy (data rate config 594 mbps to receive sensor data ) test in ZCU 102 board ,is any problem?
i use vivado 2019.1 generate mipi_dphy RX  ip (data rate config 594Mbps). When I use vcs  sim , complie error.
info as follow:
MIPI sim file as follow:4.jpg
refer solution:https://www.xilinx.com/support/answers/56390.html.
vcs vision: 2015.9
what's the problem?lib less?
Hello @taylor91
Thanks & regards
Leo
Scholar watari
Hi @taylor91
I'm not familiar with VCS and MIPI.
But it seems tool version issue.
Wolud you refer this document and use supported version ?
you are right,it is a version issue.
vivado 2019.1 require sim tool version  as follow:
Thanks   for  your reply  again .
In fact, i include xilinx  .vp files.They are encrypted files. Only matched  sim tool  version can decrypt(run from Vivado window also has the rule) those files .
https://forums.xilinx.com/t5/Simulation-and-Verification/Vivado2018-1-IP-simulation-files-decryption-failed-with-VCS-MX/m-p/868442#M22666
i must update sim tools to use the sim_model.
i'm sorry  for touble you again.
i use vivado 2019.1 generate a dphy config as follows:
input data rate 594 Mbps (DDR), sim also can't  get frame header(test in ZCU102 also has the problem),sim wave as follows:
4 lanes RXSYNCHS  effective  not in same time.
sim file as follows(tools VCS O-2018.09) :
21.jpgsim_model as follows.
looking forward your reply.
@karnanl     the problem as above.
Hello @taylor91
Could you please share the following signals from your sim ??
rxdatahs
rxvalidhs
rxactivehs
rxsynchs
soterrhs
sotsyncerrhs
cl_rxactivehs
dl_rx_state
dl_en_hs_rx_term
lp_00_r
lp_01_r
lp_10_r
lp_11_r
Thanks & regards
Leo
Hello @karnanl,
sim error has  been solved. The reason why dphy can't get  frame header is that sensor model  function doesn't meet mipi Specification.
This  is mipi Specification  require timing in HS-MODE:
this is our sensor model output(the timing too short),and  dl<n>_ errsoths signal effective:
Then I change the sensor model ,dphy can capture correct data.
Thanks for your help >_<
Thanks & regards
taylor91
Hello @taylor91
I've also seen some MIPI IP VIP model behavior from major company does not compliant with MIPID-PHY spec.
Thank you very much for debugging this and sorry for my late response.
Could you please close this thread, so other community user can learn from your experience.
Thanks & regards
Leo
