MIPI DSI Transmitter Subsystem Demo HW
the hardware validation described in the product guide PG238 "MIPI DSI Transmitter Subsystem v2.0" is done with the zcu102 board and a mipi display. How was the display connected to the board? Which FMC card is used?
Thank you very much
Re: MIPI DSI Transmitter Subsystem Demo HW
Hi @sevenclock,
This is the same design for MIPI CSI2 RX IP and MIPI DSI TX.
Check the PG232 (MIPI CSI2 RX IP). The equipment use for MIPI DSI TX is a AUOS DSI Display panel (B101UAN01.7_H/W 1A) with ribbon cable. It is then connected to the LI-IMX274MIPI-FMC Camera sensor module (which is the MIPI CSI2 input).
Florent
Florent
Hi @sevenclock,
Florent
Florent
Scholar austin
http://www.wiki.xilinx.com/x4%20Software%20Tools%20and%20System%20Requirements-4.1%20Hardware
https://www.leopardimaging.com/LI-IMX274MIPI-FMC.html
Is the MIPI camera used by a few folks here in the reference designs.
More will be listed as they get debugged and working.
Austin Lesea
Principal Engineer
Xilinx San Jose
