MIPI DSI Transmitter Subsystem HW Connectivity
SDI Signals convert to the MIPI DSI Outputs via DSI lanes with SLVS signalling, Also If the MIPI DSI Lanes has to have connected to MIPI CSI Lanes, how is it possible?
So what IP core we should use whether CSI/DSI to connect with CSI-2 lanes of the External Board.
How to go to 10 bit RGB101010 on DSI IP Tx Subsystem?
Thanks & Regards,
Prasanna Daram
Tags (3)
Re: MIPI DSI Transmitter Subsystem HW Connectivity
Hi @daram123,
I am not sure about what you are asking.
However, Xilinx has MIPI CSI-2 and MIPI DSI TX solutions as well as a UHD-SDI IP.
You might want to start by looking at these IPs and their documentation and let me know if you have further questions.
Florent
Hi @daram123,
Florent
