MPSoC -- DisplayPort does not work at high resolution
We are developing a MPSoC board using XCZU19EG. It is mostly working. But the PS DisplayPort output is stuck at high resolution (e.g 1920x1080 ). The circuit is based on the ZCU104 board (two lanes output from PS-GTR). For the testing, we are using PetaLinux X-server and matchbox. And using xrandr command to change the screen resolution.
Here are some photos.
Any ideas for troubleshooting this?
Thank you,
--fuji
Re: MPSoC -- DisplayPort does not work at high resolution
Hello @yfuji38
Did you try it on another display monitor? Does it shows similar results?
Please test Xilinx DPDMA example design with your setup.
Follow following procedure :
1. Create project for ZCU104 board in Vivado 2019.1
2. Create block design and In block design add Zynq US+ MPSOC PS IP.
3. Run Block automation
     Click on Run AutomationClick on Run AutomationClick on Run Automation
    Select apply board preset option and click OKSelect apply board preset option and click OKSelect apply board preset option and click OK
4. Connect pl_clk to maxihpm0_fpd_aclk and maxihpm1_fpd_aclk as follows:
  Clock connectionsClock connectionsClock connections
5. Run Synthesis. After synthesis completion export hardware ( File > Export > Export Hardware) without selecting bitstream option and Click OK.
6. Launch SDK from Vivado  (File > Launch SDK) and Click Ok with default options
7. In SDK, create New Board Support Package (File > New > Board Support Package). Select options as follows and Click Finish:
It will bring up Board Support Package (BSP) Setting (or you right click on BSP select Board support package setting to get this window shown below) change psu_dp driver to dppsu from avbuf and click Ok. It will automatically build BSP.
 psu_dp driver for PS DPpsu_dp driver for PS DPpsu_dp driver for PS DP
7. Double click on system.mss and click on Import DPDMA example
DPDMA exampleDPDMA exampleDPDMA example
Tick option below and Click Ok.
8. Connect DisplayPort Monitor to ZCU104 and test example design. It should show half green display on your monitor and UART should show following log:
DPDMA Generic Video Example Test
Generating Overlay.....
HPD event .......... ! Connected.
Lane count =    2
Link rate =     20
Starting Training...
        ! Training succeeded.
DONE!
.......... HPD event
Successfully ran DPDMA Video Example Test
Please note maximum supported resolution for PS DisplayPort controller is 4k30. Please check https://www.xilinx.com/support/documentation/user_guides/ug1085-zynq-ultrascale-trm.pdf (Chapter 33) for more details.
Bhushan
Mentor
Mentor
Hi @yfuji38
It's hard to investigate the route cause without movie file...
Would you post movie file instead of your pictures ?
Best regards,
Hi @bpatil,
Thanks for your suggestion.
First, I tried out it with a couple of monitors and a DisplayPort-HDMI converter. Please find attached table. Curious to say, one monitor works fine at 1920x1080 along with DisplayPort-HDMI converter.
About the DPDMA example, the Vivado/SDK project needs some modifications to fit our XCZU19EG board. I will let you know the result.
Hello @yfuji38
Please check https://www.xilinx.com/support/answers/71773.html and make sure you are not using Passive Adaptors.
It will be much better; if you can perform test your monitor with Xilinx Board with DPDMA example.
Bhushan
Mentor
Mentor
Hi @yfuji38
Did you make sure EDID on each monitor ?
Also, did you make sure power line on your designed PCB ?
At least, you are facing resolution limitation issue. No body succeed it over resolution limitation.
But you are facing some problem, too...
Would you reply my question ?
Best regards,
Hi @watari,
Yes. EDID was checked by using xrandr command.
For example,
I monitored VCC voltages using JTAG-sysmon. No issues found.
Hi @bpatil,
About DP to HDMI converter, I am using an active adapter.
I got back to original monitor (X2283HS, DP input) and tried out the DPDMA example. It shows "Training succeeded". The monitor detected 1920x1080 60Hz video signal. However, the screen is blank.
Hello @yfuji38
Monitor should show half green display. I hve tested this on ZCU104 board it works well.
Did you tried other monitor as well?
Which version of Vivado you are using?
There was old issue in which unplugging and plugging DP cable causes issue of blank display on monitor. But still you should get half green display at least for the first time.
Please check https://forums.xilinx.com/t5/Video/Displayport-standalone-on-ZCU104/m-p/975025#M25330
Bhushan
Hi @bpatil,
I am using Vivado/SDK 2019.1.
Now I found that it depends on the monitor. A half green screen was displayed on the ON-LAP monitor. Looking at UART output, in case of blank screen, re-training happened once. Probably something wrong happens to the DisplayPort after a re-training.
Good case (ON-LAP 1503 HDMI input + DP-HDMI adapter):
Lane count =	2
Link rate =	20
DONE!
Bad case (X2283HS DP input):
Lane count =	2
Link rate =	10
DONE!
HPD pulse ..........
	! Re-training required.
Lane count =	2
Link rate =	10
DONE!
.......... HPD pulse
Mentor
Mentor
Hi @yfuji38
Can you measure HPD pulse width when you are facing this issue on X2383HS ?
Also, would you share the whole log by xrandr --verbose and xorg.0.log file ?
It seems EDID issue or X-Window issue...
Best regards,
Hi @watari,
In case of X2383HS monitor, HP_DET pulse was generated once when xdpdma_video_example was executed. Please see below oscilloscope screenshot. As the pulse width is 572 us, it should be an IRQ event. On the one hand, no pulse appeared in case of ON-LAP monitor (shows half green).
About Linux log, please find attached files.
Thank you,
Mentor
Mentor
Hi @yfuji38
I'm probably sure that the route cause is EDID or X-Window.
I suggest you to make sure DPCD value, if you want to find a workround.
Would you try it ?
Best regards,
Hi @watari,
Thank you, but I have no idea how to access DPCD. Do you know any software/tool for that?
Mentor
Mentor
Hi @yfuji38
The easy way is to refer and modify Xilinx DPDMA example.
Would you try it ?
Best regards,
Hi @yfuji38
As per the AR mentioned earlier, Display port to HDMI adapters are not supported by Xilinx.
Passive adaptors will not work for sure. Active adaptors might work but it is up to the customer to do its own characterization to make sure it will work.
I would start by testing with a Displayport monitor
Florent
