Visitor mskim
Mipi demultplexer?
hi,
I want to demux the Mipi signal
I want to bypass only one of several cameras (Mipi signals).
Please give me a tip.
thanks,
Re: Mipi demultplexer?
Hello @mskim
1. If you do not have any plan to do video data processing on the FPGA you can use MIPI D-PHY RX/TX IP, otherwise you will need to use MIPI CSI-2 RX Subsystem /TX Subsystem instead.
2. Please notice that Xilinx MIPI IPs do not support link turn-around.
( RX will only receives data, TX will only transmits, no reverse data communication )
3. You need to create a custom logic to select PPI signal from MIPI RX to MIPI TX.
4. Please use US+ device since this device I/O can natively support MIPI D-PHY.
5. Please use Vivado 2018.3 ( or later version) , since MIPI CSI-2 TX and MIPI CSI-2 RX has similar data interface start from 2018.3.
Thanks & regards
Leo
Hello @mskim
Thanks & regards
Leo
Visitor mskim
hi,
I'll ask you one more.
It is said to be in the middle (PPI MUX).
Could you explain this? Or I would like to ask for references.
thanks.
HI @mskim ,
The PPI multiplexer is just a multiplexer you have to design yourself.
PPI just mean PHY-Protocol Interface. This is just how the interface of the phy is called
Florent
Visitor mskim
Thank.
It was very helpful.
Hello @mskim
Pardon me. I found that MIPI D-PHY RX cannot be connected to MIPI D-PHY TX directly.
See picture below. The ports in red-square cannot be connected directly.
-- We are going to add a feature to make MIPI D-PHY RX--> TX pass-through connection in the future.
    But it is not available for now.
For current IP version. suggest to to use VDMA to connect MIPI CSI-2 RX to MIPI CSI-2 TX.
MIPI Example design mentioned in PG232 Chapter5 may give you a better picture of the system connectivity.
Thanks & regards
Leo
