Modifying IP properties
Dear Forum,
I need to force Vivado 2017.3 to pull in v3 of the HDMI IP as opposed to v2, which is the default.
http://www.wiki.xilinx.com/Xilinx+V4L2+hdmirx+driver#Related%20Links-Change%20Log
At the bottom of this page there is a note to say that Properties must be modified to pull-in v3 version of the IP's..
For any given project, where would I find the following IP properties so that I can edit them?
  • Hdmi_rx_ss: C_HDMI_VERSION 3
  • Vid_Phy: C_INT_HDMI_VER_CMPTBLE 3
David
Tags (3)
Re: Modifying IP properties
Hi @dje666,
I recommend you to move to 2018.1. The drivers are ready for HDMI. And of course the BSPs are already available for ZCU102 and ZCU106
Florent
HI @dje666,
Quick question: Why not using a version of vivado which has the v3? It will (really) much easier and might avoid issues
Florent
Hi Florent,
Yes, switching to 2017.4 or later would be better, but I'm locked into 2017.3 right now, so instructions on how to proceed would be useful.
If I do make the move...... In your opinion which version of the Xilinx tools should I move to?
I need to ensure that I have board-support, BSP support PetaLinux support and driver support for HDMI IP in MPSoC-EV devices running on ZCU102 and ZCU106 dev-kits.
TTFN.
DJE666
Hi @dje666,
Florent
