Multiple TPG to Video Mixer - Petalinux
Trying to connect two TPG's to Video Mixer streaming.  Can this be done?  TPG's have output ports required but the Mixer driver doesnt seem to support this on the layers.  Correct?
Re: Multiple TPG to Video Mixer - Petalinux
Hi matthew.singer@elbitsystems-us.com
The drivers for the TPG and the video mixer are using different frameworks: TPG driver is a v4l2 driver and the video mixer is a KRM DMS driver. So you will not be able to connect them and use the driver.
You could always configure the 2 IP directly through their register space in the linux user space, not using their driver.
Else you need to push the data from the TPG to memory and then read back from memory to the video mixer.
So if I connect the TPG to framewriter, how do I pass that memory back down to the mixer?
This should be handled by the linux driver.
You might want to refer to the VCU TRD. It has an example of multistream using the Video Mixer
The TRD has the mixer output to HDMI. If the ouput is to DisplayPort via a framewriter, what's should the the mixer output be connected to in the device tree?  kmssink complains if there is no connector.
You have 2 options:
  • Use the live input of the DP controller
  • Send the output of the video mixer back to memory using another video frame buffer write
PS. This is a different question, could you kindly open a new topic if you have following uestions?
HI matthew.singer@elbitsystems-us.com
Is saw that you have opened a new topic for your following question:
https://forums.xilinx.com/t5/Video/Video-Mixer-to-DP/m-p/1027030
I hope the community can answer else I will try to help you (but this is not something I have already done)
Could you kindly mark a reply as solution to close this thread?
