Named port connection 'm_axis_video_TVALID' does not exist
I am working on a video pipeline design and want to use the video test pattern generator (v_tpg).  In a test project I select the v_tpg IP from the IP catalog, configure it, and then let it generate the outputs.  The out-of-context synthesis for the IP fails with a serious of errors like the following:
ERROR: [Synth 8-448] named port connection 'm_axis_video_TVALID' does not exist for instance 'inst' of module 'v_tpg_0_v_tpg' [d:/Work/prj_ip_test/prj_ip_test.srcs/sources_1/ip/v_tpg_0/synth/v_tpg_0.v:205]
I then created an example design for the v_tpg IP using the "Open Example Design..." option.  Run synthesis on the example project yields the same sort of failures.
The v_tpg is configured for 2 samples per clock, 12 bit data width, and a maximum frame size of 4096 x 3072.
I am currently running Vivado/HLS 2017.3.
Any ideas why I am getting this error, even on the example design?
DornerWorks
https://goo.gl/8wtknW
Re: Named port connection 'm_axis_video_TVALID' does not exist
Hi @corrin.meyer,
Using the steps listed in PG103, I can successfully synth/implement/generate a bitstream for the example design using Vivado 2017.3.
Based on the error you are seeing it looks like the encrypted source file is not being called properly. On Windows-based operating systems the recommendation is to make your working directory path as short as possible to work around the Windows 260 character limit.
If you are on windows can you re-try from "D:\X\"?
If you are on Linux, can you post your log so that we can take a better look at the issue?
Sam
Xilinx Video Design Hub
Hi @corrin.meyer,
This is a known issue of the TPG (related to the HLS compiler) which only happen on Windows machine. It is under investigation with development.
Sometimes changing the configuration for sample per clock or bit per pixel can work.
Florent
Florent
Hi @corrin.meyer,
The patch for windows to fix this issue is available in AR#70445 .
Florent
