No VDMA channel found
when I tried porting zynq base trd from 15.4 to 18.3 I get an error,(I want my TPG probed)
xilinx-video amba_pl:vcap_tpg: No Video DMA channel found
xilinx-video amba_pl:vcap_tpg: /amba_pl/vcap_tpg/ports/port@0 initialization failed
xilinx-video amba_pl:vcap_tpg: DMA initialization failed
my device tree is
tpg_input_axi_vdma_3: dma@40020000 {
#dma-cells = <1>;
clock-names = "s_axi_lite_aclk", "m_axi_s2mm_aclk", "s_axis_s2mm_aclk";
clocks = <&misc_clk_0>, <&misc_clk_1>, <&misc_clk_1>;
compatible = "xlnx,axi-vdma-6.3", "xlnx,axi-vdma-1.00.a";
interrupt-names = "s2mm_introut";
interrupt-parent = <&intc>;
interrupts = <0 33 4>;
reg = <0x40020000 0x10000>;
xlnx,addrwidth = <0x20>;
xlnx,flush-fsync = <0x1>;
xlnx,num-fstores = <0x1>;
dma-channel@40020030 {
compatible = "xlnx,axi-vdma-s2mm-channel";
xlnx,datawidth = <0x10>;
xlnx,device-id = <0x2>;
xlnx,genlock-mode ;
tpg_input_v_tc_1: v_tc@40070000 {
clock-names = "clk", "s_axi_aclk";
clocks = <&misc_clk_2>, <&misc_clk_0>;
compatible = "xlnx,v-tc-6.1", "xlnx,v-tc-6.1";
reg = <0x40070000 0x10000>;
xlnx,generator ;
tpg_input_v_tpg_1: v_tpg@40080000 {
clock-names = "ap_clk";
clocks = <&misc_clk_1>;
compatible = "xlnx,v-tpg-8.0", "xlnx,v-tpg-5.0";
reg = <0x40080000 0x10000>;
xlnx,s-axi-ctrl-addr-width = <8>;
xlnx,s-axi-ctrl-data-width = <32>;
xlnx,vtc = <&tpg_input_v_tc_1>;
tpg_ports: ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
xlnx,video-format = <0>;
xlnx,video-width = <8>;
tpg_out: endpoint {
remote-endpoint = <&vcap_tpg_in>;
vcap_tpg {
compatible = "xlnx,video";
dmas = <&tpg_input_axi_vdma_3 1>;
dma-names = "port0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
direction = "input";
vcap_tpg_in: endpoint {
remote-endpoint = <&tpg_out>;
please help
Tags (4)
Re: No VDMA channel found
Hi @sundar19
Could you share the full log, it would help.
Florent
