Visitor gnleaf
No video output on Video Deinterlacer
IO: 74.25MHz 1080i@60Hz input and 148.5MHz 1080p@60Hz output
About the register configure,
height register:   0x1000 0010   0x438
width register:    0x1000 0014   0x780
mode register:   0x1000 0004   0x14
control register: 0x1000 0000   0x7
But it no video output.
thanks,
gnleaf
Re: No video output on Video Deinterlacer
Hi @gnleaf ,
The video deinterlacer IP is a discontinued IP. You might want to use the video processing subsystem IP (VPSS) which is included for free in vivado 2018.3
Florent
Hello @gnleaf
This is very limited information you have shared with us.
lets start with following details
1.custom card or xilinx evaluation board
2. source and sink information
3. example design or custom design
Thank you
Visitor gnleaf
Is it configure error?
Hi @gnleaf ,
Florent
