Voyager
Voyager
Petalinux: VCU reset failed
I have desing like
but I get like below, may I know the solution for it ?
failed to get reset gpio for vcu.
 Best regards
Re: Petalinux: VCU reset failed
Hi @msh
Why are you changing the reset level between EMIO GPIO and AXI GPIO? Can you try the following
&processing_ss_vcu_0 {
reset-gpios = <&To_VCU_axi_gpio_v4lnx_rst_0 3 0 0>;
Florent
Voyager
Voyager
update from me
I connected EMIO from PS IP to VCU reset. This is accepted as reset and system loads. Though I cannot see this reset port automatically appearing in device tree. I have to add to user defined device tree.
My question: Is this is only way ? does VCU cannot accept AXI GPIO ?
Best regards
Hi @msh
Can you share you HDF file? I will try on my side.
Florent
Voyager
Voyager
hi @florentw
Strangly GPIO_reset is not appearing in pl.dtsi file after generation. Hence I have to add it via system_user.dtsi file.
Please see the attachment.
Best regards
Hi @msh
Note that not all cases are covered in the Device Tree Generator. I guess the reset of the VCU through AXI GPIO was skipped as for most cases user will use the PS GPIO as the VCU will be used with the ZynqMP processor. However, it should not be too complicated to add to the DTG so I will see what I can do.
Florent
Voyager
Voyager
I added the GPIO reset in system-user.dtsi for VCU. But still VCU donot accept it and drviers are not loaded. I get message that gpio reset for VCU failed when I start petalinux.
Where as with EMIO connection thats not the case. It pass.
So why does VCU accept EMIO reset but not GPIO ?
HI @msh
I think it should be fine to use the AXI GPIO but you need to make sure that the device tree is correct.
The easiest way is to use the EMIO as the Device Tree Generator adding the property for you.
Florent
Voyager
Voyager
Hi @florentw
Thank you for your reply
in both case the reset gpio is not added via device tree generator. I have to manually add in system user device tree.
Where i see that EMIO works and GPIO donot.
Best regards
HI @msh
Can you try to connect the xslice to only the VCU reset? It seems that currently you are connecting the reset to both your custom IP and the vcu
Also looking at your system-user.dtsi, you are never adding the reset-gpio property under the vcu node. This is an issue. This is what it should look like for the EMIO (refer to the VCU TRD 2019.1)
vcu_0: vcu@a0100000 {
			reset-gpios = <&gpio 119 0>;
Florent
Voyager
Voyager
hi @florentw
I am using zynq ultrascale + zcu106
In user define dtsi I have the definition
1. for EMIO 0
reset-gpios = <&gpio 78 0>;
2. for gpio AXI, 3rd output pin
reset-gpios = <&To_VCU_axi_gpio_v4lnx_rst_0 3 0 1>;
Hi @msh
Florent
