Pixel interceptor design
  Does anyone have a simple pixel interceptor design or an xapp that would explain how to do this?
Thanks!
Scholar watari
Re: Pixel interceptor design
What do you mean by a pixel interceptor?
Can you provide a more detailed description of what you are trying to find?
Chris
Video Design Hub | Embedded SW Support
Hi Chris
   I have LVDS signals coming through into the FPGA (from the Toradex iMX6) and I am now just passing it (no intercepting whatsoever for now) to the LCD screen. What I am trying to do is to have the FPGA overlay a new image onto the existing LVDS signals and then display to the LCD screen. I would appreciate if you could give me ideas on how to do that.
Hi @vivienwwp,
LVDS is a voltage standard and can be used for many applications.
What video standard/format is being used to send video to the LCD screen?
To overlay a new image, you will need to have an IP that is able to understand your video stream format before any overlay can be completed.
Sam
Xilinx Video Design Hub
Scholar watari
Hi .@samk
  The LCD screen I have has the RGB Vertical striped structure, supports 16:10 WXGA, 16.2M colors (RGB 6 bits + 2 bits dithering). Active screen size 1280H x 800V.
Is there a Xilinx IP that is able to do this overlay?
