Observer elahi
Problem in Transcoding a video to lower resolution using Multi-scaler and vcu
Hello all,
I want to transcode a 720p video into 480p video on zcu104 board running linux. I'm using Xilinx Multi-scaler ip core and VCU. So I have to do 3 operation:
1. Decode 720p video into raw frames using vcu
2. Scale down 720p frames to 480p frames using multi-scaler
3. Encode 480p frames using vcu.
I use following command:
gst-launch-1.0 filesrc location=akiyo.mp4 ! queue ! qtdemux name=demux demux.video_0 ! h264parse ! omxh264dec ! queue ! v4l2video0convert capture-io-mode=4 output-io-mode=4 ! "video/x-raw, width=853, height=480, format=NV12, framerate=25/1, interlace-mode=progressive, colorimetry=smpte240m" ! queue ! omxh264enc ! filesink location=final.mp4
but I get the following error:
WARNING: erroneous pipeline: could not link queue2 to omxh264enc-omxh264enc0
Could you please help me find the reason behind this?
Thanks in advance
Tags (3)
Re: Problem in Transcoding a video to lower resolution using Multi-scaler and vcu
Try runing gst-launch with the -v option to print out more verbose messages.  That might give you more information about why the queue2 couldn't be linked to the omxh264enc.
Chris
Video Design Hub | Embedded SW Support
Scholar watari
Hi @elahi
As @chrisar already mentioned before, you need some option or environment setting to do debugging.
Would you add the following option, too ?
--gst_debug-level=3
