Participant krunal_h_bhavsar
Problem regarding to FIR compiler v2.0
             I am trying to simulate for FIR complier v2.0. I am using System Generator 9.1 and it's example which is given in ..........
..<sysgen_tree>/examples/getting_started_training/lab7/. I am using this lab7 example........ But when I simulate with FIR bloack it gives me error........which is given below........
Summary of Errors:
Error 0001: Internal Error
     Block: 'lab7/FIR Compiler v2_0 '
Error 0001:
Reported by:
Details:
An internal error occurred in the Xilinx Blockset Library.
Please report this error to Xilinx (http://support.xilinx.com),
in as much detail as possible. You may also find immediate help
in the Answers Database and other online resources at http://support.xilinx.com.
Error occurred during "Rate and Type Error Checking".
How can I solve this error.........Please help  me......
Thank you,
Krunal
Re: Problem regarding to FIR compiler v2.0
Hi Krunal,
The examples included with System Generator have been tested and should work. Make sure you have the latest IP Updates for your version of ISE as well as the latest version of System Generator for DSP. Can you please open a webcase at http://www.xilinx.com/support/clearexpress/websupport.htm so we may better assist you.
RJ Duran
Customer Application Engineer
Technical Support: http://www.xilinx.com/support
Xilinx User Community: http://forums.xilinx.com
RJ Duran
Thank you sir for your reply,
             I have updated my IP and now it working...........sir can you help me in other prolem.......I am trying to make delta sigma ADC using XAPP155 but it not working properly even though I have downloaded from xilinx and when I open it into ISE it gives me error and when I remove that error I can not get correct answer if possible please help me.......
Thank you.........
Krunal
This sounds like there is a problem with your tools setup.  Please create a WebCase with Xilinx technical support to debug this specific issue.
