Problems using dsp48 / timing constraint failed
Hi all!
At the moment I'm facing the following problem.
I created an IP-template with CIP, than I wrote
an FIR-Filter in VHDL. If I try to implement the design
an timing error occurs.
With the help of ISE timing analysis I found out that
there is to much logic in one path.
The biggest delay occurs between the dsp48-cores
on Signal PCIN / PCOUT.
My VHDL design is like the following:
MUL_ADD: process(Bus2IP_Clk, Bus2IP_Reset) variable PRODUCTS : PRODUCTS_TYPE; variable ADD : signed(0 to 23); begin if Bus2IP_Reset = '1' then ADDA_delay <= (others => '0'); elsif Bus2IP_Clk = '1' and Bus2IP_Clk'event then MUL: for I in 0 to TAPS loop if I <= (TAPS/2) then PRODUCTS(I) := STAGE(I) * COEFF(I); else PRODUCTS(I) := STAGE(I) * COEFF(TAPS-I); end if; end loop; ADD := PRODUCTS(0)(0 to 23); AKKU: for I in 1 to TAPS loop ADD := ADD + PRODUCTS(I); end loop; ADDA_delay <= ADD; end if; end process MUL_ADD;
Due to that I use the DSP48 indirect because I do not instance it I do not really know
how to solve the problem. Is there a way to put some "delay FlipFlops" between
PCIN / PCOUT without instance the DSP48 directly?
I would appreciate if anyone could help me with this issue!
Regards Chris
Re: Problems using dsp48 / timing constraint failed
If I understand you code correctly, you're creating a big adder chain without any pipeline register after each tap. I would suggest you rewrite the adder chain code so that a pipeline register is added after addition of each product (see attached snapshot is an example with cascaded adders for Virtex6).
end loop;
Cheers,
Jim
Hi Jimwu!
Thanks for your reply!
In the meantime I got same answer from my local Xilinx FAE.
Chris
