Question Regarding VDMA tripple buffer resolution
     I am using vdma triple buffer code provided by xilinx,It's working for resolution 752*480. But i want to use it for other resolutions like 2128*16 or 4256*6384 its not working,only first buffer will be filled with data and other two buffers contains junk data. Please suggest me if there is any solution .
Thanks and regards
Nishith Kumar.
Tags (2)
Re: Question Regarding VDMA tripple buffer resolution
Hi @nishith.kumar,
My first assumption is that your pointers to the buffers are not set correctly or that there is an issue with your size/stride registers. Can you confirm that you are setting the Start addresses correctly for each of the resolutions and/or post their values?
Sam
2018-12-12 13_35_39-Xilinx Documentation Navigator 2017.2 -  http___www.xilinx.com_support_documenta.png
Xilinx Video Design Hub
Hi @nishith.kumar,
Do you have any updates on this? Was @samk's reply enough for you?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Florent
hi @florentw ,
                     Here I can use  maximum resolution  2128*1197. So issue solved using 32 buffers maximum 38,000 frames stored .
                    Thank you for your support.
Thanks and Regards
Nishith
