RGB to HSV and Back
Hello!
I want to convert RGB into HSV and back for some image processing application. Before writing any code for it, I just wanted to know if there's any simple way to do it. Also, I will need the Xilinx Image Statistics IP which has been discontinued. Is there any way to retrieve it back or some other hack, please let me know.
Thank you!
Best Regards,
Urvish
Re: RGB to HSV and Back
Hi urvish@htic,
It was discontinued because there was not enough business to keep maintaining this IP.
You might want to try to write your own using vivado HLS, starting from C/C++.
Florent
Hello urvish@htic
You will need to use older Vivado to use this IP.
But it is not recommended since this is discontinoued IP, and no technical support for this IP.
But I think RGB-to-HSV color conversion module should not be so complicated to create
http://www.javascripter.net/faq/rgb2hsv.htm
Thanks & regards
Leo
Dear @karnanl,
Thank you for your assistance. But can you please tell me why did they discontinue such an IP. And that I want to write a  RGB to HSV module in VHDL which is compliant to AXI4S Standards.
Best Regards,
Urvish
Hi urvish@htic,
Florent
Dear @florentw,
I really enjoy reading your answers and admire your expertise! I've already started writing this RGB2HSV IP, but can I write Image Statistics IP?
Best Regards,
Urvish
Hi urvish@htic,
Thanks. Glad to know that I am helpful for the community ;)
Yes you should also be able to write the image statistic IP. You will have one input stream and maybe store the result in a register space.
You might want to ask on the Vivado HLS board if you have some question on how to write this.
Best Regards,
Florent
Yes, I'll be glad to get that help as well.
Best Regards,
Urvish
