Visitor rileywoodson
SDI rx initialization problem with Artix xapp1097 simulation using Vivado 2016.4
I am running a behavioral simulation of an SDI RX using the guidelines and files from XAPP1097 (v1.0.1) using Vivado 2016.4. I'm using dru_sim.v for the simulation and supplying a 50 MHz free running clock for the SDI and DRP clock (FXDCLK_FREQ = 50000000 and DRPCLK_PERIOD = 20) and supplying a 148.5 MHz ref clk. I've run the simulation for 10ms and rx_fabric_reset_out = 1 and rx_mode_locked = 0. When I look at the  a7gtp_sdi_wrapper_gtrxreset_seq module I see the state machine stuck at state wait_pmareset waiting for a falling edge on RXPMARESETDONE. Module inputs RXPMARESETDONE stays high and GTRXRESET_IN stays low. The sequence of events are as follows:
1. RXPMARESETDONE goes low to high at 180 NS.
2. GTRXRESET_IN goes low to high at 540 NS.
3. RXPMARESETDONE goes low at 621 NS.
4. DRPRDY has two positive pulses.
5. GTRXRESET_IN goes low at 1760 NS.
6. RXPMARESETDONE has a 20 PS positive glitch at 2020 NS  (may not be consequential. This does not generate an input to the state machine).
7. RXPMARESETDONE goes high at 2180 NS. The state machine is stuck at state wait_pmareset waiting for a falling edge of RXPMARESETDONE which never occurs.
8. Inputs remain static to the a7gtp_sdi_wrapper_gtrxreset_seq.v module and its output DRP_OP_DONE stays low which appears to prevent initialization from proceeding.
Any help would be appreciated. Thanks in advance.
Re: SDI rx initialization problem with Artix xapp1097 simulation using Vivado 2016.4
Hi @rileywoodson,
Are you using the version 1.01 of the xapp1097? Refer to AR#60303
Hope that helps,
Yes. I'm also using dru_sim.v. I'll try simulating the ac701_sdi_demo provided in XAPP1097 and see if I get a different result.
Visitor sgjws8
回复: SDI rx initialization problem with Artix xapp1097 simulation using Vivado 2016.4
Hi!
Have you solve the issue yet?My design is not running correctly,too.Same issue like yours.
Thanks for your helping !
I found that I had set parameter GT_SIM_GTRESET_SPEEDUP = "true" for a7gtp_sdi_wrapper_GT.v. The simulation doesn't work unless GT_SIM_GTRESET_SPEEDUP = "false". I also set parameter WRAPPER_SIM_GTRESET_SPEEDUP = "false" in a7gtp_sdi_wrapper_common.v. Unfortunately, this means the simulation has to run for several milliseconds for initialization to complete.
Newbie songgangjie
Hi!
ah,you mean that after setting parameter WRAPPER_SIM_GTRESET_SPEEDUP = "false",simulation could be running correctly?Now my design's parameter is "TRUE",so thanks for your helping,it is necessory to try it again.
Thanks for your helping!
Newbie songgangjie
Thank you very much for your helping!After setting the parameter,the SDI RX could be locked now.Thanks!!!(^_^)
