Visitor mustafa60
SMTPE296M
Hi all,
I need to decode the information taken from a HD 720p camera which uses SMTPE296M embedded sync and progressive.  I write a code in verilog but it seems there is some problems at decoding EAV and SAV part. Can anyone show me where ı am wrong?
`timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 07.08.2019 14:49:29
// Design Name:
// Module Name: bt1120torgb
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module bt1120torgb(
EndOfLine,
StartOfFrame,
iReady,
txout0_seven,
txout1_seven,
txout2_seven,
txout3_seven,
txclk_in,
oYCbCr,
data_valid,
reset
input iReady;
input [6:0] txout0_seven;
input [6:0] txout1_seven;
input [6:0] txout2_seven;
input [6:0] txout3_seven;
input txclk_in;
input reset;
output [23:0] oYCbCr;
output data_valid;
output StartOfFrame;
output EndOfLine;
reg[7:0] Y_eight;
reg[7:0] C_eight;
wire[7:0] Y;
wire[7:0] C;
reg[7:0] oY;
reg[7:0] oCb;
reg[7:0] oCr;
reg [23:0] oYCbCr;
reg [10:0] Hcount=11'd0;
reg [9:0] Vcount=10'd0;
reg Hsync,Vsync;
reg data_valid;
wire StartOfFrame;
reg EndOfLine;
assign StartOfFrame = (Hcount==11'd0 && Vcount==10'd26) ? 1:0;
always@(negedge txclk_in or negedge reset) begin // Y_eight and C_eight can be a assign block
if(!reset) begin
Y_eight<=0;
C_eight<=0;
end
else begin
Y_eight<= {{txout1_seven[0]},{txout0_seven}};
C_eight<= {{txout3_seven[0]},{txout2_seven}};
end
end
assign Y= Y_eight;
assign C= C_eight;
always@(negedge txclk_in) begin // horizontal synchronization pulse
if(Y==8'hB6)
Hsync <= 1;
else if (Y==8'h80)
Hsync<=0;
else if ( Y==8'h9D)
Hsync<=1;
else if (Y==8'hAB)
Hsync<=0;
end
always@(negedge txclk_in) // HORİZONTAL AND VERTİCAL COUNTERS
begin
if(~Hsync) begin
Hcount<= Hcount + 11'd1;
if (Hcount==11'd1280) begin
EndOfLine<=1'b1;
Hcount<=1'b0;
Vcount<= Vcount+ 10'd1;
if (Vcount>=10'd26 && Vcount <=10'd745)
data_valid<=1'b1;
else
data_valid <=1'b0;
if(Vcount>10'd749)
begin
Vcount<=10'd0;
end
end
else
EndOfLine<=1'b0;
end
else
Hcount<=0;
end
// assign oYCbCr=iReady ? {oCr,oCb,oY}:24'd0;
if(iReady)
oYCbCr <={oCr,oCb,oY};
else
oYCbCr <=24'd0;
end
//**************************************************** YC to YCbCr 4:2:2 converter
if(!reset) begin
oY<=0;
oCb<=0;
oCr<=0;
end
else if (data_valid) begin
if(~Hcount[0]) begin
oY<=Y;
oCb<=C;
end
else begin
oY<=Y;
oCr<=C;
end
end
end
endmodule
Tags (3)
Re: SMTPE296M
I think it's need your detailed description to locate the problem.
Visitor mustafa60
Re: SMTPE296M
Firstly sorry i couldnt give a response for a while. The problem is that although i got the general idea about embedded sync.,  decoding the information is a little bit complicated for me in HDL. Information comes in such a way that txout0+-, txout1+-, txout2+-, txout3+- and txoutclk+- differential pairs form the camera as 7 bits.
I first need to decode this 7 bit to 8 bit. ([6:0]txout0+- is a first 7 bit Y and [6:6]txout1+- msb of Y info etc.) and extract the EAV and SAV information from the coming datas of the frame. In my code i first concenate datas as 8 bit in two different channel Y and C. Then i changed Hsyns pulse according to EAV and SAV infos according to specification sheet. I guess first problem is the way i did it in my code. Is it right?.
Also, data_valid flag informs me when the video data comes and i activate the output when the data_valid flag is asserted as 1. Does this way create me an empty space in between frames. Or should i take all information from the channel?.
Lastly, my EndOfLine and StartOfFrame flags are arramge like in the code. Is the logic behind it true?
I appreciate all answers and thank you a lot.
