Participant bivin
SP701 MIPI CSI Interface
I'm having few queries regarding MIPI interface with FPGA.
1) In SP701 evaluation board, CSI and DSI interface is connected to two different banks. CSI being connected to 2.5V bank using a resistor network and DSI is connected to 1.8V bank. But in xapp894 it is given as below for CSI.
Here how HSUL_12_S_HR is compatible with 2.5V bank , please clarify.
2) If i'm implementing below circuitry for DSI (in Artix 7), can i connect MC2002 IOs to 1.8V bank ?
3) If i'm implementing below circuitry for CSI (in Artix 7), can i connect MC2001 IOs to 1.8V bank ? Is 2.5V bank voltage mandatory for CSI interface ?
Please reply.
Re: SP701 MIPI CSI Interface
Hello @bivin
>3) Please confirm with Meticom ICs (MC20901,MC20902) i have to use always 2.5V banks in Artix 7 .
You can go to Meticom URL and download their datasheet. You need to use 2.5V. (Requirement from Meticom)
http://www.meticom.com/resources/Datasheets/MC20002-V1_08.pdf
http://www.meticom.com/resources/Datasheets/MC20001-V1_09.pdf
>2) Is there any validation tool/checklist for the same ?
You can use Vivado to check whether your pin assignment is correct or not.
Please create a test design, plan your pin-assignment, and implement your test design.
Vivado will check whether your pin-assignment is good to go.
>1) Is there any specific IO to which i need to connect HS_P/N as well as LP_P/N ?
Could you please check PG202 Appendix C and UG471.
Thanks & regards
Leo
Hello @bivin
No.
No, it is not a mandatory but I believe MC2001/MC2002 only support 2.5V.
-- The requirement/limitation is on Meticom devices.
It should be possible I think. (See table below). Could you please check UG471 ?
Thanks & regards
Leo
Participant bivin
Hi @karnanl
Thanks for the reply. I'm having few queries.
Hello @bivin
Thanks & regards
Leo
