Scale down to 640x480 with vprocss_v2_5 IP
Dear ALL
great day !!
I successfully Scale down video I/P video from 1080p to 720p by using vprocss_v2_5 I.P.
My question is could we scale down to 640x480 resolution if the input video is 1080p. and if it possible then please tell me the extra configuration has to be required for 1080p to 640x480 conversion using vprocss_v2_5 I.P
Thank you
回复: Scale down to 640x480 with vprocss_v2_5 IP
Hi @deepg799 ,
I am quite sure I already tested this downscaling. Again, you might want to refer to the example design. Just modify the resolution for in and out.
Florent
Yes you can, 480p setting is just like 720p.
I has tried with below code but this code is working for 720p not for 480p.
XVprocSs_Config* vprocss_config;
vprocss_config = XVprocSs_LookupConfig(XPAR_XVPROCSS_0_DEVICE_ID); // same ID
if(vprocss_config == NULL){
xil_printf("ERROR:: VProcess Lookup failed\r\n");
return(XST_FAILURE);
XVprocSs_LogReset(&vprocss);
memset(&vprocss, 0, sizeof(XVprocSs));
status = XVprocSs_CfgInitialize(&vprocss, vprocss_config, vprocss_config->BaseAddress); /
if(status != XST_SUCCESS){
xil_printf("ERROR:: VProcess Initialization failed\r\n");
if (rx_mode == 0) {
resolution = 4;
else if (rx_mode == 2){
resolution = 6;
FRAME_HORIZONTAL_HSIZE = (u32) resolutions[resolution][5]; // rx_mode
FRAME_VERTICAL_LEN = (u32) resolutions[resolution][0];
thisCase.width_in = FRAME_HORIZONTAL_HSIZE;
thisCase.height_in = FRAME_VERTICAL_LEN;
thisCase.Cformat_in = XVIDC_CSF_YCRCB_422;
thisCase.IsInterlaced = FALSE;
thisCase.width_out = 640;     //1280;
thisCase.height_out =480 ;   //720;
thisCase.Cformat_out = XVIDC_CSF_YCRCB_422;
//Stream In
XSys_SetStreamParam(&vprocss, XSYS_VPSS_STREAM_IN, thisCase.width_in, thisCase.height_in,
thisCase.Cformat_in, thisCase.IsInterlaced);
//Stream Out
XSys_SetStreamParam(&vprocss, XSYS_VPSS_STREAM_OUT, thisCase.width_out, thisCase.height_out,
thisCase.Cformat_out, thisCase.IsInterlaced);
status = XVprocSs_SetSubsystemConfig(&vprocss);
XVprocSs_ReportSubsystemConfig(&vprocss);
@nathanxI could helpful for me if you give some suggestion for the above mentioned code, the above mentioned code is working fine for 720p scale down but it is not working for 480p.
Scholar watari
Hi @deepg799
Do you want to keep aspect ratio ?
If yes, it is hard to do it.
Best regards,
Hi @deepg799 ,
Florent
@florentwCan you tell me, what is the  max. scaling down is possible using vpss,
In my case input to a scalar is 1080p & I am scaling down to 720p but scaling down to 480p is not working for me. your suggestion could be helpful for me.
@watari can you tell me what is the max. scaling down ratio which vpss is supports.
Scholar watari
Hi @deepg799
VPSS doen't have any limitation about scaling down ratio.
You only need to consider aspect ratio, if ex. you down-scale from FHD to VGA.
Because an aspect ratio is different between them. (FHD -> 16:9, VGA -> 4:3)
Best regards,
Hi @deepg799 ,
As mentioned by @watari , the VPSS does not have a real limitation. It might no be happy with resolution below 32 pixels but usual video resolutions should work
Florent
