Sensor Demosaic C simulation model
I am considering Sensor Demosaic v 1.0 as a replacement for CFA (Color Filter Array Interpolation v 7.0).
I created the Example design, but I can't do C simulation. How do I do CSIM with demosaic?
My image quality rating environment is based on C because CFA provided a Cmodel. RTL simulation is difficult because it takes too much processing time.
Re: Sensor Demosaic C simulation model
Hello @ctk ,
At this point, there is no C-Model for the Sensor Demosaic IP like the CFA IP.
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
Hello @ctk ,
Best regards,
Kshimizu
