Serial transceiver txoutclk is not being generated
I've designed the TX only SDI design for ZCU102 from ZCU106 12G-SDI pass through example design.
Modified the example design as required for TX only design.
The serial transceiver reference clock is given from the FMC card, which has a 148.5 Mhz  clk oscillator (default clk out).
I am not able to get the txoutclk from the GT core.  I've double verified my reference clk and transceiver constraints on the .xdc file.
Vinay
Vinay Shenoy
Re: Serial transceiver txoutclk is not being generated
Hi @vinay_shenoy,
How are you checking the TXOUTCLOCK?
Could you make sure the GT is not held in reset?
Did you check the configuration (MGTREFCLK selection?).
I suspect a problem with the SDI GT in the design. Adding the GT signals to ILA for debug. Will update you
Vinay
Vinay Shenoy
@vinay_shenoy
From the last email from your SR, you were able to get TX and RX RESETDONE. Is txoutclk still not being generated?
Hi @vinay_shenoy
Thanks and Regards,
Hi @florentw @xud
I am away from this debugging for sometime now. Surely I'll update the findings and observations.
Vinay
Vinay Shenoy
Hi @vinay_shenoy,
Any update on this?
